20 Most Recent Dell Studio 1737 Laptop Questions & Answers
2answers
I need password for dell studio 1737 bios setup ,
the pass is 123456789
10/28/2022 11:25:01 PM • Dell Studio 1737... • Answered on Oct 28, 2022
3answers
How do you use usb sticks?
1. Plug thumb drive or USB into the USB port on the laptop.
2. Go to My computer and see if you see "Removable Disk" if yes then you double click here and you will see the contents of the USB drive.
3. load something from the laptop or PC to the usb just drag document or program from PC drive to usb drive.
4.Go to site called "Ehow" to gain more information.
Note of caution donot just pull USB from the usb port it will erase all the information and the USB drive will then be rendered usless.
5. Remove USB in the proper manner that is goto the "task bar and look for the "safe to remove hardware" icon or go to the "my computer" icon select the "removable disk" icon ( right click) and the select "eject" if the drive is busy or a message comes up that it is then closed all programs associated to it and the "Eject" the drive and remove it from the USB port.
I hope this helps. Have a good day!
9/14/2022 4:41:33 AM • Dell Studio 1737... • Answered on Sep 14, 2022
6answers
Web cam says to close other video streaming
I have an answer! I've tried many times to fix this problem on my laptop, even talking to two dell reps in the process(which was worthless). Finally I found the problem(for me, at least)- my webcam's driver was not compatible. If you haven't tried this already, go to your Device Manager, click the plus sign next to Imaging Devices, and select Integrated Webcam. Right click that and select Update Driver Software. I downloaded the latest driver it found and restarted my computer, and miraculously my webcam central was back to normal. I hope this helps you too!
10/19/2021 2:36:04 PM • Dell Studio 1737... • Answered on Oct 19, 2021
Cannot log in, repeated message "User Profile" problem
You need a system repair disk so that you can boot up to a dos command prompt. Sometimes you might be able to get a command prompt from booting up in Safe Mode. Windows 8 and 10 have a startup repair that will allow you to get to a command prompt in the advanced options of the startup repair options. If you can get to a dos command prompt there is an hidden administrator account on all computers just for when a problem like this happens. You need to make the hidden administrator account active then you can sign on with it and go into the control panel and create a new user account with administrative rights (or as an administrator). You can then copy all your data from your old user account to the new user account that you created. You might get a message such as "you don't have permission to this account or folder'" when you try to copy you data from one to the other, just click ok and it will allow you to have permission. To activate the administrator account just type this at the dos command: net user administrator /active:yes (when you are done you just change yes to no and the account will be hidden again) but you can always leave it active. Enable the Hidden Administrator Account on Windows 7 8 or 10
3/9/2018 2:45:47 PM • Dell Studio 1737... • Answered on Mar 09, 2018
DELL STUDIO 1737, WITH WIN 7, WILL REBOOT AT
operating system issue try to repair os or make a clean new os installation (make backup before you go for clean instillation... best try to repair and restore.... thanks
8/18/2017 4:29:16 AM • Dell Studio 1737... • Answered on Aug 18, 2017
Recover deleted messages dell video chat
Reocver video on my iPhone How can I recover a deleted video from my Samsung Galaxy S7 edge? If it is possible, How to do? It is true when people say that the millennial generation is inseparable from their gadgets such as android phones, laptops, music box. This is all because of the hole in our lives that our gadgets fill is huge, the role that they assume in our lives as employers, employees, teachers, students and even as members of our families somehow surmounts anything that has ever been invented. Option 1: Recover Deleted Audios from Google Drive Backup Option 2: Retrieving Through FoneDog Step 1: Download and Install FoneDog Step 2: Select Data Recovery Option Step 3: Enable USB Debugging Step 4: Allow Debugging Step 5: Select The File Type Step 6: Choose The Mode Step 7: Recover Your Audio/Music Video Guide: How to Recover Deleted videos from Your iPhone More reading: How to Restore Deleted SMS on iPhone 7 and Later Version? How to Recover Deleted Viber Messages from iPhone 7/7 Plus
7/18/2017 9:24:49 AM • Dell Studio 1737... • Answered on Jul 18, 2017
I can not find the serial number on my laptop
Dell uses the Service Tag number as the serial number for your device. Every device has a unique Service Tag number.
2/17/2016 1:16:25 AM • Dell Studio 1737... • Answered on Feb 17, 2016
How to remove stuck cd dell studio 1737
You can right click on the CD drive on your computer and choose 'Eject'. If that does not work, here is a link to a youtube video that should work for a slot load cd/dvd computer. https://www.youtube.com/watch?v=gmGWIjtOsvA
1/30/2016 2:13:16 PM • Dell Studio 1737... • Answered on Jan 30, 2016
How to Upgrade Bios on laptop without battery
10/14/2015 10:14:48 AM • Dell Studio 1737... • Answered on Oct 14, 2015
2answers
How do I reduce long running scripts that slow my computer down?
Go into internet settings advanced and disable active x
9/16/2015 10:19:03 AM • Dell Studio 1737... • Answered on Sep 16, 2015
Laptop very slow
Try booting to safe mode by holding F8 when it starts. Depending on the operating system, this should bring up a menu that has options. Pick safe mode with networking. And see if that helps. If it does then you need to run Malwarebytes on it to see if that is one of the problems. www.malwarebytes.org
9/16/2015 2:09:25 AM • Dell Studio 1737... • Answered on Sep 16, 2015
Certain keys stopped working even after replacing the keyboard.
Hi, I work for Dell's Social Media Team and would like to you help with your question. Please release flea power and let us know the status. Pradeep, Social Media and Community Professional Order Status: http://dell.to/1fgKSTr Download Drivers: http://dell.to/1hcxG98q
6/9/2015 4:45:53 AM • Dell Studio 1737... • Answered on Jun 09, 2015
Where can I find media clip for dell 1737
Hi, Can you please let me know the exact files you are looking for ? Did you save the files somewhere and missed the location or Is it the common folder you are looking for where the media files are stored ? Thanks Seb
6/2/2015 6:28:54 PM • Dell Studio 1737... • Answered on Jun 02, 2015
I have changed motherboards, they are the same, but the new one has an ATI Video chip M826G. Do I have to have a new BIOS version to run this new one?
The BIOS would support the new chip as it comes with the motherboard. Check the connections for a problem.
4/7/2015 10:23:29 PM • Dell Studio 1737... • Answered on Apr 07, 2015
Is the heat sink the same on a motherboard that does not have a video chip and one that does?
No it is not. Different shape and size. Thermal paste is always good to use to create good contact between heatsink and chip.
4/6/2015 6:42:20 PM • Dell Studio 1737... • Answered on Apr 06, 2015
3answers
I forgot my windows login password for a dell studio 1737 laptop
What OS are you having?On XP you can try this:Boot computer and press Ctrl+Alt+Delete twice when you See Windows welcome screen / login screen. It'll show classic login box. Now type "Administrator" (without quotes) in username field and leave password field blank, press Enter and you should be able to login Windows.Now you can reset windows password from "Control Panel -> User Accounts".On Win 7 or Vista:Ctrl+Alt+Delete won't work, you have to use some windows password recovery software. I recommend Windows Password Recovery Tool 3.0 .
3/16/2015 2:05:56 AM • Dell Studio 1737... • Answered on Mar 16, 2015
How to close a video streaming application to start video
Press CTRL+ALT+DEL Select "start task manager" Right click on this and end
1/5/2015 3:37:55 AM • Dell Studio 1737... • Answered on Jan 05, 2015
Where is refresh key in
For Vista or Win 7 If your operating system is VISTA / Win 7, tap F8 key when you see the Dell logo. It will take you to advanced boot menu options which include `Repair your Computer'. Select that option and enter your password if asked, then you will see a list of options like `system restore', `command prompt', etc. The last option says Dell PCicon1.png restore or something similar to that. Select that option and follow the screen. Start the computer. As the computer starts, press the F8 key until the Advanced Boot Options menu appears on the screen. Press the (Down Arrow) to select Repair Your Computer on the Advanced Boot Options menu, and then press Enter. Specify the language settings that you want, and then click Next. Log in as a user who has administrative credentials, and then click OK. Click Dell Factory Image Restore. In the Dell Factory Image Restore window, click Next. Click to select the check box for Yes, reformat hard drive and restore system software to factory condition. Click Next. The computer is restored to the default factory configuration. When the restore operation is completed, click Finish to restart the computer.
11/29/2014 5:31:31 PM • Dell Studio 1737... • Answered on Nov 29, 2014
Dell Studio 1737 Laptop Logo
375 questions posted
Grand Canyon Tech
Grand Canyon Tech
SmartAviator
SmartAviator
View Most Popular
Studio Dell
  • Studio Dell
Most Popular Question
web cam says close other video streaming
  • Computers & Internet
