Wow - Have you tried beating it with a kitchen sink?
The first problem is - Not visible in windows.. Sometimes windows will try to assign an existing drive letter to a new device, because that new device was previously that same drive letter. A common problem with usb drives. Not really heard of it with hard drives, or is this a USB HD?
Go into Drive manager again, and locate the drive by its name, in the lower window. Right click on the drive and choose change drive letter. Assign it a drive letter you know is unused. It should now show up in the windows explorer with the drive letter you assigned. Now you can right click the drive and choose format. If you have trouble with format, then the drive might be locked by special backup software or hard drive password. I cannot cover that here and now. Others may help if you repost with further problems.
Sure, you can recover your data. but you have to rely on some data recovery program.
You can try Card Data Recovery. Justinstall this program on your computer and use the function "allrecovery", after a while your deleted files will be back soon.
Manufacturer's Website: Go to the manufacturer's website (visit the official Samsung website in this case). Click on the support section, search your monitor model by product name or model number, and download your monitor model for the user manual. User manuals usually list codes and other relevant information.
User Manuals Online: Many people post user manuals online for all types of electronic devices and peripherals. You can search for your monitor and look for the user manual at sites such as ManualsLib, ManualsOnline, or Retrevo. Most of these sites will catalog user manuals for a wide variety of devices posted online by users and are normally free to access.
Physical User Manual: If you still have the original box or packaging with your monitor, there might be a copy of the user's manual in that box or enclosed. It might be in an actual printed booklet or perhaps just some links to online resources. Check under a section entitled 'Remote Control Codes' or 'Setup Instructions'.
Contact Samsung Support: If no luck finding it to download or to help you, there is contact support available, they should know where that information is, and be able to send it to you or refer you.
With these, you should be able to find the user manual for your Samsung 32" curved screen display and enter those codes.
ENGLISH ONLY please.
Samsung washing machine wf90f5e5u4w
Hello good afternoon, I want to ask for help, I have a faulty module and I wanted to ask if you have the electronic diagram for the Samsung DC92-01240C washing machine, the machine model wf90f5e5u4w, I would really appreciate it if you could, thank you. greetings Antonio Paulo
Sounds like the phone is on a contract with a different supplier.
Contact the original SIM supplier, EE, O2, Vodaphone etc and ask them to unblock the phone.
Question edited to add the further information.
Has to be in the manual? Did you pull the mains plug overnight?
That panel is called OSD (on screen display) and can be set to stay on for up to 200 seconds. Page 39 refers, and you can also reset it to factory defaults.
https://downloadcenter.samsung.com/content/UM/200803/20080329132905671_BN59-00716A-Eng.pdf
That sounds like a voice command problem for this Chicago, Illinois based channel. Refer to the station by its number on your subscription package, like "Alexa channel 1105 on tv".
https://www.google.com/search?q=wgn+-+tv
Samsunghttps://www.samsung.com > answer > ANS00087622
Amazon Alexa is now built-in on Samsung TVs and smart monitors! You can ask Alexa to change the channel, open apps, search for movies and shows, play music, ...
Tom's Guidehttps://www.tomsguide.com > How-to > TV
Apr 5, 2023 - Step 1: Set up your devices. First, make sure that both your Samsung TV and your Amazon Alexa device are set up and workings.
Can Alexa change TV channels? As long as you're using the TV's built-in tuner, you can use Alexa to change TV channels. Just say something like "Alexa, channel 7 on TV" or "Alexa, change channel to [channel name] on [TV name]."Nov 1, 2022
