Food Mixers Logo
Anonymous Posted on Nov 18, 2012
Won't Turn on
Ross Keen
Level 3:
  • KitchenAid Master 1,365 Answers
  • Posted on Dec 01, 2013
Ross Keen
KitchenAid Master
Level 3:
Answers
1365
Questions
0
Helped
583551
Points
2445
Check carbon brushes, check for broken wires under back cover.
Kitchen aid artisan model # KSM150PSBU
You have put the "chalk thing" back in incorrectly, it only fits one way, use a torch and look in the hole and line the missing corner on the "chalk thing" up with the blocker.
Jul 26, 2013 • Food Mixers
Kitchenaid mixer 600 won't turn on
bread is very tuff on mixers. always buy the strongest mixer that you can afford. im guessing the field in the motor fried.
My KitchenAid mixer won't turn on
Sounds like the carbon brushes under the black side caps or failing that a broken wire.
Model khm9qwh5 won't start
This particular model has some sort of internal electronics that require a charge before the unit will function. As a result, when allowed to sit in the cabinet for a long period of time it will simply not turn on. Instead, all you will hear is a "click" noise when you try to power it on. When you get the dreaded "click" noise leave plugged in for several hours and try again.
Kitchenaid mixer motor quit , I dont really see any thing wrong with the brushes.
Obtain a copy of the Repair Part List for your model from Kitchenaid.com.
Download a Copy of the Kitchenaid Service manual.
http://www.kitchenaidparts.be/centers/servicemanual/mixer.pdf
First, you may want to adjust the mixer's speeds:
1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
anymore. Leave the bottom screw alone for now.
2. Use a dab of white paint or paper whiteout to mark the positions of the Phillips screws.
3. Plug in your mixer and Set the speed selector to "Stir".
4. Turn each top screw One full turn couterclockwise (alternating between Left and Right)
Keep making one full turn at the time (for both left and right) until the motor starts running.
5. Put your hand near the Agitator shaft and allow it to brush your finger slightly. Use your
watch or clock and start counting the number of times the shaft touches your finger in
60 seconds. The correct count should be 60 RPM (Rounds Per Minute). If it is less
or more than 60, give each screw 1/4 turn counterclockwise or clockwise and start counting
again. Now tighten both lock nuts.
6. Set the speed selector to "6" and turn the bottom screw either clockwise or counterclockwise
to achieve a speed of 180 RPM.
For your reference, the planetary RPM's for the 5-qt. tilt-head Artisan Stand Mixer are as follows:
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
Second, if the mixer won't run:
Remove the Control Plate Assembly (36), the Phase Control Board (39)
and the motor Governor Assembly (35). Inspect for loose connections,
burnt or damaged components. If they seem to look OK, re-assemble
them and test the mixer. If the motor still won't run, then I might suspect
a defective Phase Control Board (39).
Mixer won't start. Fell on its side and on/off lever was bent. Straightened and it now moves back and forth as it did before. I took out the two black screws at the top which hold in magnets on...
Get A Copy of the Repair Parts List from Kitchenaid.com
Make sure the Speed Lever and and the Speed Link are in place
and operating smoothly. The two Large black screws you are referring to
are the Motor Brushes Caps. The Carbon Brushes are keyed and
designed to be inserted into the Motor Housing but one way. If you
insert them in wrong, they will not make contact with the Motor Coils
and you mixer will never run.
All you have to do now is adjust the mixer speeds (if necessary):
Remove the screw holding the End Cover and locate the three screws from the Control Plate.
All three (2 top left and right, and 1 bottom) must be adjusted.
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
1helpful
Won't turn on
Get a copy of the Repair Part List for your model at Kitchenaid.com
On each side of the Motor Housing(1) is the large black Brush Motor
Cap(23). Each Carbon Brush(19) is keyed (one corner is not square)
and is designed to go into the Motor Housing slot but only one way.
Each Carbon Brush must make contact with the Motor Coils. The
motor will not turn if one or both does not come in contact with the coils.
If the brushes are too worn out, of course they won't touch the coils
neither and your motor will not run. You can purchased new brushes
on Ebay if they need to be replaced.
1helpful
I could not regulate the speed as usual. Hubby removed the phase control board and a new one was purchased #9706595. It arrived and was installed and now the mixer won't even turn on. HELP please.
The K5SS is very similar to the 5-QT Artisan KSM150.
You need to adjust the mixer speeds. Obtain a copy of the K5SS Repair Part List from Kitchenaid.com. Remove the screw holding the End Cover and locate the three screws from the Control Plate. All three (2 top left and right, and 1 bottom) must all be adjusted. 1. Loosen the lock nuts enough & Turn the 2 top screws clockwise until they cannot be turned
Stir speed - 60
Speed 2 - 95
Speed 4 - 135
Speed 6 - 180
Speed 8 - 225
Speed 10 - 280
3helpful
2answers
Took out/put back black brushs/motor wont turn on
Hi TUBEARS, from what you’re describing, I suspect that one or both of the brushes is (are) not seated properly when you reinstalled them. The brushes need to be installed so that they both seat correctly on the armature's commutator or you won’t get any ‘juice’ to the motor. See the illustration below:
I'd suggest removing them again and making sure the concave contact face rests completely on the armature’s commutator. If you've turned it 90 degrees too much, it won’t seat properly and you get no power to the motor.
It would also be helpful to have the Parts List manual on hand. If you're lacking one, you can download a PDF version from the KA website at: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the first file K45SSWH0.pdf (341.41 KB) listed under Parts List (1) and then check to verify this matches your mixer model.
Turn to pages 6 & 7, titled “Motor And Control Parts”, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. Locate Illus No 32, Brush holder assembly that includes Illus. Nos. #18, 21, 22, 23 & 31, and Illus. No. 19, Brush & Spring assembly respectively.
The Parts List illustration along with the picture above regarding the orientation of the brushes should get your mixer powered back up and operational. Good luck! I hope this helps. Howard, Burke, VA
If this solution has been helpful to you, please rate it, thanks! -hslincoln
Top KitchenAid Food Mixers Experts
ZJ Limited
ZJ Limited
Paul Carew
Are you a KitchenAid Food Mixer Expert? Answer questions, earn points and help others
