I want to install it but i don't have the CD Installer, is there any other way to get a free installer software? Hope to get a reply ASAP.. Mahalo
You can free download from here: http://www.buffalo-technology.com/en/airstation-nfiniti-high-power-gigabit-broadband-adsl2-modem-router-downloads.html
Then reset your password:
->open a web browser window and enter 192.168.11.1 in the URL field and press enter. You will get a prompt to enter a username and password to access your router settings. You should enter "root" (without quotes) as the username and leave the password field blank, then click OK. You are now taken to a page where you can configure your Buffalo wireless router.
->Click on the Admin Config button on the top right of this page. Enter a name for your AirStation and click Apply. Wait for the router to restart with the new setting, you may have to refresh your browser window.
->Next click on the Password button in the small row of choices under Admin Config. The Administrator name is fixed as "root" however, you should now choose an Administrator Password (8 characters or less) and enter it in the two fields provided, then click Apply. Wait for the router to restart, and you will be prompted to login with the username "root" and the new password you just set up. If you choose a password over 8 characters long, you will be unable to login and will have to reset your wireless router by using the pinhole on the bottom.
If you need any kind of technical assistance you can contact support cell at http://www.vtechsquad.com/
SOURCE: installation broadband router linksys WRT54G v5
Please connect the laptop to the linksys router with the cable provided. On the linksys, connect the able in any port from 1-4. Please do not connect the laptop to the Internet port.
From the start menu, select Run. Type in cmd and press enter. At the prompt, type in ipconfig. On the line that says Default Gateway -> this is the address of the router when connected to the computer and (DHCP being on).
Make a note of the Default Gateway and type it in the address bar in an Internet Explorer window. At the login prompt, leave the username prompt blank and type admin for password.
This will allow you to access the web GUI.
Hope this helps :) Kindly leave a good feedback. Thanks...
SOURCE: Dlink wireless router software download
I gave you the link already?
Well heres it again
http://support.dlink.com/products/revision.asp?productId=DWL-G122
DWL-G122 I beleave?
SOURCE: where can I get a free d-link DI-624 installer online?
There are multiple revisions of the DI-624,
each with version specific drivers, firmware, installation guides, and
other resources. Please use the descriptions below to
identify your revision.
The links will take you to the drivers and install guides.
Note: The revision is located on the label on the bottom of the device next to H/W
The DI-624 Rev. A has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624v.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624
The DI-624 Rev. B has 2 antennas.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revBv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI%2D624%5FrevB
The DI-624 Rev. C has only 1 antenna.
<img src=http://support.dlink.com/prod_img/revisions/DI-624_revCv.jpg>
Driver here: http://support.dlink.com/products/view.asp?productid=DI-624_revC
SOURCE: D-Link DIR-635 Wireless N Router won't install
hi! I will be more than glad to assist u in this concern. I encounter that problem as well. I have a dlink as well. I follow the cd installation and it wont detect the modem or internet. but if the computer is connected to the modem it works..what i did. i didnt follow the cd installation, I set it up manual by typing at the url of your brower, 192.168.0.1 that is the ip add of the router and it will ask the username and password, by default the username is admin and the password, just leave it blank..in the setup page, select on manual internet connection setup.. there is an option for dhcp-which is auto detect, static ip or pppoe. but first check what kind of setting u have with ur isp, if u are using a username and password, u have to select the pppoe, if the isp provide gave u a static ip address u have to select static.. to know your ip address settings, click start, run and type cmd and it will show dos prompt, from there type ipconfig/all, it will list the ip address, subnetmask, default gateway, dns server.. I hope this will solve ur concern..
SOURCE: forget wireless-G broadband router, how do I change it
There is a reset button in the back, small pin hole, hold it in for 10 seconds.
This will restore it to when it was new so you will have to reset all your settings.
The user will be- admin and the password -linksys
or check your manual if these don't work.
