Machine must be 20 years old #966 krups expresso machine
SOURCE: Krups model 865 Coffe and Expresso maker manual
I NEED A MANUAL FOR A 865 KRUPS COFFEE AND EXPRESSO MACHINE, I DID NOT GET ONE
SOURCE: Machine Fault Error No 06
ERROR CODE 06 and/or CODE 07 on the XP7245 model is requesting you to remove the water filter. I had this problem and I called Customer service for the answer. Once you have removed the filter they indicated to allow the unit to go thru set up mode again and then put the filter back in once the machine no longer has an error code.
I didn't actually try it b/c I took my maching back to the store I bought it from only 2 weeks after buying it to get a new one.
SOURCE: Krups XP2070 - expresso part - timing
It sounds like your flow meter is not working properly. Most likely it goes for about 5 seconds, stops and starts blinking with all the icons on. You can replace the flow meter and get it working again.
