20 Most Recent Krups Small Appliances Espresso Machine Questions & Answers
I have just had the same problem with my Krups XP7240 and I discovered (quite by accident!) that it was the magnetic float inside the water tank which was causing it. I think the float must have let some water in and always stayed on the bottom even when the tank was full. As the float was in an enclosed plastic column it was a bit hard to access, but through sheer desperation I snapped a plastic fork in half and wedged the handle section under the float to keep it off the bottom and this works nicely. It is not professional by any means but I was quite pleased with my innovation :)
The only down side to this 'method' is that the opposite is now true and when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid killing the element completely.
I would imagine that the only professional way to get this sorted out is to replace the tank (or float if it is accessible?). Good luck!!
Krups Small... | Answered on Jul 16, 2019
You need to specify model, they are not all the same.
Krups Small... | Answered on Jun 17, 2019
Error 05 I would normally associate with a distributor problem,
New distributor
New barista seal
New tamping piston seals
New tank seal
It is not a job for the faint hearted.
Krups Small... | Answered on Aug 29, 2018
Error code 07 on my Krups XP 7220 coffee machine what to do? Nick
Krups Small... | Answered on Jul 01, 2018
The only oil use for this units is mineral oil you can buy it at any grocery store
Krups Small... | Answered on Jan 19, 2018
E8050 does not exist in the Krups info I have, EA8050 does though. You need to remove the tamping piston and unhook all the wires from off the PCB on the side. Then the boiler assembly is attached to the base with 3 screws. This will allow you to tip the boiler over enough to get access to the screw up through the bottom that holds that plastic flange thing on the bottom of the ejection rod while you at the same time have another screwdriver in the screw from the top into the only screw that you see inside the boiler. One of the screws will come undone, it doesn't matter which one. That will allow you to remove the shaft that the seal you are trying to replace fits around. It is called a Barista seal part number MS5015004
Krups Small... | Answered on Dec 02, 2017
The hose connected to the heating element has unattached or is leaking.
Krups Small... | Answered on Sep 04, 2017
The best thing you can do is find the receipt and exercise the guarantee. The problem you have is not a simple fix.
Krups Small... | Answered on Mar 24, 2017
Good afternoon... On my krups machine and failure code appeared 8025 09. Said It was the temperature probe. I'd like to get a picture of the temperature probe and its cost. With the best regards
Joao Araujo
Krups Small... | Answered on Jun 16, 2016
It's not a job for the faint hearted on one of those machines. The 2 places most likely to be leaking are the barista seal on the bottom of the boiler or the distributor which is a motor driven tap that sends the water from a single pump to do various functions. There are also various hoses in there that are under high pressure and can fail in an instant. I have just read the error codes and it seems that the barista seal is going to be the LEAST likely cause of the leak but I would replace it during the process if you are going to have that area close to being apart.
Krups Small... | Answered on May 31, 2016
m
hi ! my name is Tommy . I need the capsel holder for the dolce gusto delonghi
Krups Small... | Answered on Apr 06, 2016
Hi, my name is Katelyn, and I help with the marketing for Dolce Gusto. There is a live chat with a specialist on our Web site (http://www.dolce-gusto.us/Public/Contact-Us.aspx) or feel free to call the consumer services at 800-745-3391.
Krups Small... | Answered on Apr 03, 2016
That model is ancient, you are going to be scratching to find a handbook for one of those things. You may be better to ask specific questions relating to what operation of the machine you don't understand. They make good coffee, were relatively reliable and now any parts you may need are now obsolete.
Krups Small... | Answered on Feb 26, 2016
I had the same problem with the XP7240. The rubber seal in the plunger that pushes out the coffee cake after brewing is worn or dirty. You need to romve the cover by taking of the top (screws in the bean collector and cover tray for cleaning tablet). You have to be rough because parts are clicked together. The face of the machine comes off by pulling it upwards (it is just clamped with plastic nudges). Once that is done you remove the 4 screws that were hidden by the stainless steel face. Then remove the electronic board (leave connections on except for bean grinder and boiler). Grinder can then be removed followed by the cream cover. Remove the 15mm steel nut on top of the arm. Remove the front and display. Then use a torix on top of the brew plate and an allan key on the bottom of the plunger. Unscrew, remove spring and seal (very small cup). Let me know if you need more instructions (take a rainy sunday afternoon to do this)
Krups Small... | Answered on Dec 29, 2015
Inside the water tank there is a magnetic float which is causing the problem. This float is moving always on the top of the water tank as you fill it with water and in reverse as the water level goes down then the float is moving down to bottom also. So as the magnetic float is moving up and down is giving the signal for the water level if it is full or empty.
So possibly now the float is stuck in the bottom and even if you have refill the tank this is still on the bottom of the tank. This can happen from many reasons. First could be that the plastic column that the float is moving is full of scale and it can not move up and down freely any more so you can clean it from scale by decaling it and even clean it with a wire brush.
A second possibility could be that float have a tiny hole and some water enter in the float and this make it to stay on the bottom of the tank. You can visually inspect it and if possible you can dry out the water and weld with a super glue the hole if possible, if it can not be fixed then you need a new float.
If you wand to fix it temporary until you find a new float you can a plastic clip or similar to secure it always on the top however you when the tank is empty it doesn't register so you would really have to keep an eye on the water level to avoid any other problems with the machine.
Good luck
Krups Small... | Answered on Aug 14, 2015
Error 6 means machine thinks it has a leak in one or more of the following
1) Distributor
2) Thermoblock
3) Pump valve
4) Pipe leakage
Repair will involve specialised tools and parts, not really the sort of job to attempt yourself. Contact Krups and get from them contact information for your local service agent.
Krups Small... | Answered on Aug 04, 2015
Unfortunately, YoTeach's initial solution is in error, I believe. YoTeach mentions that typical temps for brewing water are less than 200F, and THAT seems OK, from a couple of quick searches.
However, the component that is being replaced is not necessarily working at the same temperature as the water needs to be.
The Microtemp G4A00 series has lots of temperatures, and the TF216C means, AFAIK, that Tf is 216C(elsius). See, for example, the datasheet here:
http://www.farnell.com/datasheets/625786.pdf
Tf is the temperature at which fuse opens. So, the person ACTUALLY needs a thermal fuse that opens (breaks the connection) at 216C.
Therefore, either of the two fuse temperatures mentioned: 128 & 140C, would open too soon: i.e. at too LOW a temperature.
While 216C may seem like a high temperature (420F), for the fuse to open, the thermal fuse is often very near the heating element. For comparison, I have a Gevalia CM500 coffee pot, and the thermal fuses in my particular unit are Microtemp G4A00 184C- which is about 363F.
If anyone thinks I am in error on this, please feel free to contact me: jim underscore peak at Hotmail dot com - and I'll be happy to correct this post.
Krups Small... | Answered on Apr 10, 2015
Pompano Beach, Florida 33060, Service and Repair Krups Service Centers' mission is to fulfill our manufacturer's legal warranty obligations, to ensure the repair of your Krups product even when the warranty period is over, and also to give you good helpful advice.
ARKANSAS
Vanness, Inc.
11610 Pleasant Ridge Rd Ste 106
Little Rock, AR 72223
Phone: 501-353-2362
CALIFORNIA
CES Concord (Northern California)
1170-G Burnett Ave.
Concord, CA 94520
Phone: 925-827-1011
CES Covina (Southern California)
612 S. Shoppers Lane
Covina, CA 91723
Phone: 949-586-9479
CES Lake Forest
22500 Muirlands Avenue Suite B
Lake Forest, CA 92630
Phone: 949-586-9479
Website: www.californiaelectricservices.com
Appliance Sales & Service
840 Folsom Street
San Francisco, CA 91407
Phone: 415-777-5144
Fax: 415-495-5141
Website: www.thegourmetdepotco.com/krups/
COLORADO
Nelson Appliance
1220 E. Filmore St.
Colorado Springs, CO 80907
Phone: 719-635-1928
Website: www.nelsonappliance.com
NEW YORK
Turnpike Appliance
3495A Lawson Blvd.
Oceanside, NY 11572
Phone: 516-486-5700
Website: www.smallappliance.com
UTAH
eReplacementparts.com
7036 South Tech Dr. 185 West
Midvale, UT 84047
Phone: 801-467-6361
Website: www.ereplacementparts.com
WASHINGTON
Action Small Appliance
14603 NE 20th, Suite 3,
Bellevue, WA 98007
Phone: 425-643-9806
Fax: 425-643-9834
Website: www.actionsmallappliances.com/
Note: XP7000 Series
Only the following Repair Centers:
Turnpike Appliance
Oceanside, NY
Vanness, Inc.
Little Rock, AR
Nelson Appliance
CES Concord
Concord, CA
CES Covina
Covina, CA
CES Lake Forest
Lake Forest, CA
Krups Small... | Answered on Mar 25, 2015
Krups Small Appliances Espresso Machine Logo
298 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
manual krups il primo 972
  • Coffee Makers & Espresso Machines
