20 Most Recent Krups Orchestro 889 Espresso Machine Questions & Answers
I would contact a local small appliance repair shop locally
Krups Orchestro... | Answered on Sep 21, 2016
You might have a broken seal on the brewing unit. There is an O ring on the tamping part that often gets broken with wear. Best to carefully run it with the covers off to determine exactly where the leak is. Parts may be a problem for this model, a lot of bits & pieces are obsolete now. The O ring will be available aftermarket anyway, I've got plenty here in New Zealand.
Krups Orchestro... | Answered on Nov 29, 2015
The hot water works, but when I run coffee, the water only goes into the used BIN, NOT the spouts. I can't get the water to go through to brew the coffee..
HELP
Krups Orchestro... | Answered on Apr 19, 2015
You can download a copy of the Instructions for Use for the Krups Orchestro 889 here:
http://kitchen.manualsonline.com/manuals/mfg/krups/889.html?idRes=2156642
I believe this model may also be known as the Orchestro FNF2; the Operating Manual for which can be found here:
http://www.krups.com/NR/rdonlyres/10012184-2B94-45B3-B77E-159E8961C894/936/Orchestro_FNF1FNF2_endk.pdf
Some parts for Krups here:
http://www.smallappliance.com/product.asp?cur=USD&sid=18954&gid=18960&mid=15&pid=7105&prdCls=P&shopBy=Brand
or here
http://www.abtecparts.com/krups_espresso.htm
Krups Orchestro... | Answered on Nov 08, 2014
Did you ever get a good solution or figure out the fix to this?
Krups Orchestro... | Answered on Oct 10, 2014
I have the same machine and the spent coffee tray wasn't going in and after cycling with pressing three times then clicking three times all the lights would cycle between red and green and the machine would do nothing. It turned out to be a jammed eject motion of spent coffee. the coffee was pressed in but wouldn't eject into the coffee tray so the flap wouldn't go all the way up making the tray not go in. I took the back of the machine off and used a screw driver to "help the unit up during the cycle". When the machine would screw down and PRESS I'd not do anything but as soon as it would screw up I would lever my screw driver and HELP it up....after two or three attempts it screwed all the way up and ejected the coffee and now it seems fine.
I have been through the book and it gives no information on flashing power and clean light together. Quite often a full dismantle, clean and lubrication of the brewing unit will make things better when they are acting incorrectly.
Krups Orchestro... | Answered on Oct 02, 2014
I can supply you a part number if you tell me what country you are and a photo of the capacitor showing its position so I can look up the correct one.
Krups Orchestro... | Answered on Mar 01, 2014
There are many capacitors in that machine, where is it?
Krups Orchestro... | Answered on Feb 28, 2014
Open the steamer nozzle and let it pump until it stops by itself.
Krups Orchestro... | Answered on Oct 19, 2013
Krups Orchestro 889 Espresso Machine Logo
68 questions posted
Top Krups Coffee Makers & Espresso Machines Experts
Pierre Laplante
Ray Murphy
Marvin
Marvin
Are you a Krups Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
View Most Popular
Krups Coffee Makers & Espresso...
  • Krups Coffee Makers & Espresso...
Most Popular Question
krups orchestro
  • Coffee Makers & Espresso Machines
