If the cause only an open resistance going to the audio amplifier or a bad audio amplifier ic it is not too expensive. to isolate the problem you need first to check a bad component parts like the resistor or a shorted audio ic. but before you come up with trouble shooting you must check first the volume button in the front panel which need to replace or clean the contact of the tact switch for volume.you can use a electronic contact cleaner, to do this you need to remove the button panel at the tv.
Can you recommend someone that can do the troubleshooting at a reasonable price?
In the New York Metropolitan Area?
i'm sorry i'm not familiar in the area. will anyway i'll try to find site that offer repair service in your area.
