The phone must be programmed with the target line assigned to the number you wish to have ring at that phone. This can be done with the BCM Element Manager interface. If your BCM450 is running version 6, I think this can even be done directly from the phone, but I'm not sure of that process.
SOURCE: Callback
first off the T7208 is the phone model and need the ksu model number to know what system you are in. But you can always call that extension and if not in office it should go straight to voice mail (if any) then leave mssge to call back
SOURCE: nortel t7208
it seems like your system does not have disconnect supervision. set it to yes under trunk line data. that way the system knows when a call is released.
sean malone
SOURCE: how can i remove the "do not disturb' features in my phone Nortel T7208
hey i have the solution. push the function button, then pound, then 85. hopes this helps. i had the same problem and i worked for me
SOURCE: I have a Nortel T7208 can't change main greeting
to change the main greeting you need to get into admin programing F983 your also going to need a 7310 or 7324 or a T7316. You have to use the buttons under the LCD screen to navigate after getting into admin press AA
Press GRTG
Press GRTG again
and usually 1 is set for day
and 2 is set for night
press 1 then ok
Press REC.
Hope this helps
SOURCE: checking voicemail remotely on nortel T7208 phone
I dial my number and press ** when the VM picks up, then it should run you through the regular login process.
