Frigidaire 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
MARILYN MOMPOINT Posted on Oct 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
MY OVEN WON'T HEAT
  • Official Brand Answer 4,342 Answers
  • Posted on Nov 01, 2012
Electrolux
Level 0:
Answers
4342
Questions
0
Helped
1467926
Points
5907
Hello - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failur
1 Related Answer
Joe Sugg
  • 59 Answers
  • Posted on Sep 10, 2012
SOURCE: oven heating element won't heat
Unless you are qualified to troubleshoot appliances or work with electricity, you should probably call a repairman.
Oven won't heat
major electrical problem. call a repair man asap!
SMEG OVEN BRAND NEW WON'T HEAT
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  • Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  • If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  • When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Sep 08, 2012 • Smeg Ovens
Oven won't heat to temperature
Does it reach the temperature and then back down, or does it take too long to get to your set temperature? Either you have a faulty element or a bad communication error with the main control board.
2helpful
Hotpoint oven won't heat above 250 degrees broiler works fine as well as the stove top
either its the oven sensor rod located at the top of the ovens cavity,or your bake element could be getting a hot spot which is when it gets a discolored spot in the element and can no longer pass sufficient current to heat the oven past 250 degrees
1helpful
Ge oven jtp18 elements won't heat
The limit switch in a Ge oven usually works or is blown. I would look at the oven sensor located at the back of the oven. It should read approximately 1k ohm at room temperature.
http://www.on-timeappliance.com/ovenrepair.html
Stove top burners work but when the oven is turned on it looks like the pilot light will glow but will not ignite the oven
The problem beleive it or not is that the bake igniter is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake igniter(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of igniter make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake igniter. I know it seems improbable that if the igniter comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the igniter comes on yet the oven won't heat that a weak igniter is the cause 100% of the time
Gene...OldTech2332
The ignitor glows but the oven will not turn on
Hello Juan,
The problem beleive it or not is that the bake ignitor is weak ,and it is not drawing the proper amprage to open the gas valve.If you have a amp meter access the wires to the bake ignitor(usually behind the storage drawer) and check for 3.3-3.6 amps when oven is set to bake by clamping the meter around ONE wire wire of ignitor make sure only one wire,either one and not both.
if amp draw less than 3.3-3.6 amps replace bake ignitor. I know it seems improbable that if the ignotor comes on that it could be the problem.Professional appliance technicians who would charge a average of $250.00 to repair your oven,have found when the ignitor comes on yet the oven won't heat that a weak ignitor is the cause 100% of the time
I hope this helps,
Gene
Model: JDS8850AAS -- Oven won't preheat above 150
Hope this helps
Gene
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Whirlpool electric oven won't heat just barely
Hello & Welcome to FixYa
This indicates a open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then test the door switch. Please get back to me if you have any other questions.
Kevin
Top Frigidaire Ovens Experts
ZJ Limited
ZJ Limited
Paul Carew
Kell Le
Level 1 Expert
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
