HP Compaq nc6120 Notebook Logo
chris foley Posted on Oct 25, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Sound surge My speakers, even if I plug in external speakers or a headset, sort of do this "surging" thing. Almost like a vibrato in a voice. It ends up sounding like Ch-ch-ch ch ch ch ch ch chhhhhhhh ch ch ch ch ch ch chhhhhh..... Just got a new router, so it's not that. I'm about to try it hard wired instead of with wireless intenet.
Claudiu Rascol
Level 2:
Sergeant:
  • HP Expert 427 Answers
  • Posted on Apr 18, 2013
Claudiu Rascol
HP Expert
Level 2:
Sergeant:
Answers
427
Questions
0
Helped
53878
Points
519
Reinstall audio drivers. Clean up registry and computer.
5 Related Answers
Anonymous
  • 1226 Answers
  • Posted on Jan 18, 2008
SOURCE: no speaker sound (HP Pavilion dv6000)
there a loss connection in the speaker of your system. locate the loss connection and fix it. if hard for you fix then you should call the technician to fixed for you ..or either use external speaker so that you can hear sounds without using headset.
iqbal_del
Iqbal Husain
  • 655 Answers
  • Posted on Mar 08, 2008
SOURCE: Compaq Evo N610c No internal sound
No, you need not to install soud/audio driver if its work with external speakers. Its seems that the internal speaker of your laptop has got damaged. So you shuld call your vendor for service. If you are in warranty it will be free for you.
Thanks
Iqbal
Anonymous
  • 12 Answers
  • Posted on Mar 08, 2009
SOURCE: Sound only works with headset. No longer comes
If the sound is working through another device then it seems that the internal speakers are bad. Because if the sound card was bad you wouldn't have any sound whatsoever, same goes for drivers. Probably just some bad speakers. If you have some other external speakers try plugging them into the headphone port and see if that helps.
Anonymous
  • 27 Answers
  • Posted on May 18, 2009
SOURCE: My laptop kicks everybody else off of the wireless router including the main desktop which is hard wired to the router.
Perhaps its using its own address that is forcing the other computers to lose theirs. Under its network settings, make sure its set to DHCP. This means it will get an auto-IPadress from the router and not use its own one.
Anonymous
  • Posted on Apr 29, 2010
SOURCE: HP Pavillion HDX 9000 - No Sound from Speakers
hi all after replacment of speaker no sound comming fron spaeker,so suggest
Bosch dishwasher model # shx3ar76uc will not start after a possible power surge
Washing machines these days are as much computer as an electro-mechanical device and as such contain sensitive cmos electronics that are easily damaged by voltage surges or spikes.
It is usual to protect the laptop and desktop computers with surge-protectors but it isn't generally recognised that most computerised appliances need similar protection - radios, tv sets, top boxes, washers and even the modern fridge...
A surge protector won't protect against every surge but every little helps and when a household has most things protected it produces a sort of increased herd immunity.
I suggest you call an engineer to your washer and if the repair is going to be expensive try claiming the cost from the power company.
1helpful
Sound cuts out with "protector" message
Sounds like a bad speaker, or a speaker that is being over-driven.
3helpful
HP PL5060N 50 my plasma will not start, I have a surge multiple plug, here in Mexico electric surge is very common, when i try to turn it on, it makes a click sound and turn off, It wont even display...
The "Clicking sound is what gives it away. It would seem that your unit has some sort of PSU fault, or a problem that is shutting down the Power Supply Unit, PSU. This happens so that no further damage, and possible fire will occur.
You need to take the unit to a reputable service centre/man and ask for a firm "Quote" for the work to be done.
My speakers have no sound.
  • after all the testings of the external devices, one thing proves that the internal speaker needs replacement.
2answers
I am no tgetting sound from external speakers
Power down your machine
Unplug everything from it
Open it up
Remove your sound card and put it back in
Reverse the step and boot your machine
If it still doesn't work then you'll need to replace your sound card. You can find really good ones on Amazon for $25 or so.Remember to always turn off your speakers before you plug them into your computer. Since they are probably powered via AC adapter that surge of power could have shorted out your card. Good luck!!
Just bought Belkin surge protector 8-way with telecoms.The 3 ports are lablled "output" (2) and input (1)>I have broadband external modem (ADSL) and internal modem for use with fax.The...
Does the surge protector have a "in and out" phone socket? Plug everything into the "out" side and then run a "phone wire" from the "in" side into the wall socket,.. you should be protected.. You are putting "all your stuff" after the surge protector.. so the surge protector can do its job..
Pioneer X MT- 2000 Stereo Bookshelf Unit - No sound!
It definitely sounds like it took a surge. yhe Power Amop IC in those things are pretty sensitive. Any decent repair shop should be able to repair it for under $125.
No audio coming from my receiver
my speakers call creative on my computer wont work they use to,i hear sound but not audible
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
