Juki HZL-E80 Computerized Sewing Machine Logo
Posted on Oct 15, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Juki HZL-E80 won't turn on
I used my machine recently with no problem, but tonight it will not turn on. I checked the cord and tried a couple different outlets. The lightbulb is burnt out - could that cause the machine to not turn on at all? Nothing else appears to be wrong.
Debbi's Sewing Machine Repair
Level 3:
  • Juki Master 7,365 Answers
  • Posted on Oct 15, 2012
Juki Master
Level 3:
Answers
7365
Questions
Helped
1744577
Points
19451
No, the light bulb won't cause the machine not to work, check the
power cord to see if it's plugged into the machine correctly, if it is
then the machine needs to be checked to see if it's the power
cord or the on off switch or the machine it's self
2answers
Why is it seizing up and clocking after doing basic sewing?
Juki HZL F300 Exceed Sewing Machine at Ken's Sewing ...
www.kenssewingcenter.com/juki-hzl-f300-exceed-sewing-machine-p-30...
The Juki HZL F300 Exceed Sewing Machine is a classroom model and will exceed ...High speed sewing up to 900 spm, stitches per minute; Power at low speed ...
Juki HZL F300 Exceed 106 Stitch Computer Sewing and ...
www.allbrands.com/products/22395
$749.00 - ‎In stock
Juki HZL F300 Exceed 106 Stitch Computer Sewing and Quilting Machine +$50 Knee Lift Lever + $50 ... High speed sewing up to 900 spm, stitches per minute
Juki Exceed HZL F300 Home Deco Computerized Sewing ...
User manual
hi there
i don't know how to upload at fix ya but you can send your email and i will send to you user manual for JUKI HZL-E80 immediately.
thanks and regards
ASHRAF
CAIRO - EGYPT
[email protected]
Dirty thread
hi there,can you check please that area around lower needle bar bushing? maybe some oil drop from this area.- check the adjustment screw for lubricate hook from down maybe need to decrease the amount of oil how lubricate the hook by turning to minus direction.best regards
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
I need to know how and where to oil my juki HZL-E80 sewing machine
your machine is not a self oiling machine, you should put the oil on the needle bar, and to the bobbin.
3helpful
Double needle use on Juki HZL-E80
if the machine regular needle threads front to back NOT side to side, you can use a double needle. simply pass both threads thru all the same slots (thread one at a time so they don't get twisted up) then just before the needles, leave one out of the thread guide just above the needle. you may have to loosen the top tension SLIGHTLY, like a half number. and do NOT use a zig zag stitch without first hand cranking it thru the cycle to be sure the needles clear, or you'll make a 5.00 mistake (the cost of the double needles!)
Thread continues to jam
Hi, my wife and I just bought a Juki HZL-E80... I love the machine. I had a problem like you discribe...This problem can come from two sources...one the bobin has been installed improperly. ...or been wound incorrectly by not haveing adjusted the Bobbin tension ...I did the tension adjustment with the screwdriver supplied with the machine accessories. Also...this is a biggie...the auto matic needle threader works great...but I discovered that when I preformed this function..that I over looked the thread holder that keeps the thread even with the needle....so, the solution is to thread the needle then be sure to check that the thread coming down from the spool is placed behind the little wire holder above the needle...I hope this helps you ...because it is a wonderful machine.....Bill & Donna Bramble...Caldwell Idaho...
1helpful
I have a hisico ck563 it's similiar to the juki
check your bobbin, co'z it is not in his right position. and look at your bobbin if there is something who locked it, maybe u break a needle. there is some one left it a litle.
Buttonhole problem
When doing the button hole....after installing the button hole foot and lowering the foot....and adding the button so the automatic button hole size is determined...you lower the button hole lever it will touch the back of the button hole foot. this holds the button hole foot in the proper position...if this lever is not all the way down...the machine blips at you...check to see that it is down all the way...I hope this helps you..It truly does all that it advertises and is a great machine...BBill01
P.S. you can adjust width and length of the stich also...see instruction manual. pg 28-30
Top Juki Sewing Machines Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Are you a Juki Sewing Machine Expert? Answer questions, earn points and help others
