Disher won't clean well. It used to work fine. Then noticed deposits on the glass and plates. The door also has white gunk, dried looking particles stuck everywhere. Tried running vinegar thru it, helped slightly.
I
have the same problem with gunk and spots on dishes. I took apart the parts at
bottom covering the heating element. There is all sorts of gunk on everything.
I cleaned it all, even under gaskets and filter screen. I am neither sure what caused
it nor how to prevent it. My thinking maybe the water source. Water in my town
has gotten worse in quality and has bad smell. I use a major water filter
system for drinking water. My thought is that the heating element is drying the
water up and leaving sediment from water.
SOURCE: The dishwasher does not clean
Hi suzyb3,
Please look at my below Tip on how to ensure your dishwasher is working smoothly:
DISHWASHER NOT CLEANING PROPERLY...
Kind Regards :-)
* If this solution helped you, please rate it
SOURCE: My DMR78AHS dishwasher stopped washing. It runs
Hi If the water inlet
valve is fine and it fills with water then the issue seems to be with the float
switch assembly that is bad and should be replaced. Float assembly is found
inside the dishwasher's tub, on the bottom. The water that fills the dishwasher
lifts the float, and when it reaches a certain level, it acts as a trigger for
the float switch. The float triggers the float switch to shut off, thereby
shutting off the flow of water into the dishwasher. A defective switch may
interfere with dishwasher's filling and/or draining ability. Use voltmeter to
test the switch. Set the device to the ohms setting x 1. Take each probe and
touch them to one switch terminal each. This should produce a reading of either
zero or infinity. Continue to touch the probes to the terminals, and press down
on the switch's button. The reading should change to the opposite extreme. If
the switch fails either of these tests, you should replace it. Hope this helps...please post back for
further assistance. Daniel
SOURCE: I have a new stainless
Hello
Your dishwasher has been designed to use a liquid rinse aid. Pouring a liquid rinse aid into the proper recepticle in your dishwasher when you add dish detergent greatly improves drying performance. You can further improve drying performance by selecting the Sanitize option, in addition to the other options you've selected, and increasing the water temperature.For Best Results, use Jet-Dry Turbo
Spots and film form in your dishwasher's rinse cycle, when detergents are already down the drain. FINISH® JET-DRY® Rinse Agent works in the rinse cycle, lowering the surface tension of water and causing it to sheet. Better rinsing results in less spots and film.
If these recommendations do not improve drying time, please contact Samsung Customer Care
SOURCE: water not heating and therefore not cleaning well
Check your heating element..
Dishwasher Problems The Heating Element not Working
http://www.fixya.com/support/r4589033-dishwasher_problems_heating_element_not
Dishwasher Maintenance
http://www.fixya.com/support/r4319937-dishwasher_maintenance
heatman101
