20 Most Recent
Samsung DMT300RFS Builtin Dishwasher Questions & Answers
How do you get to the float sensor to clean it on dmt3000rfb
might be the moisture sensor nxt to the float. They are both located on the left side where the fill tank connects to the outer side of the tub. It requires removing the unit, turning it upsde down, and opening some framework to get to it. there are instructions on the low-level sensor error page here somewhere.
4/4/2017 7:38:30 PM •
Samsung...
Answered
on Apr 04, 2017
Samsung DMT300RFS dishwasher; low-level water error
A Samsung service tech showed me how to fix this one. You can take that float and the white box apart from the dishwasher and once opened, if its like mine, there will be gunk on the float and in the box at the line where it fills with water. This gunk floats in there and prevents the float from swinging and activating the switch. Just clean that gunk out with a toothbrush, I end up doing mine about once every four months, and it should work fine again. This tech said to prevent this, make sure the water is hot at the beginning of the cycle and pre-rinse the dishes-but this doesn't seem to work with mine.
4/4/2017 7:33:11 PM •
Samsung...
Answered
on Apr 04, 2017
Dishwasher blinking light
your owners manual fault guide will tell you what all blinking lights mean ie,,,how many blinks will tell you where the fault lies
4/21/2016 4:56:28 PM •
Samsung...
Answered
on Apr 21, 2016
Dishwasher stops when starting to fill
Your dishwasher is equipped with a leakage sensor located at the bottom center of the unit underneath. If any water is detected, the sensor shuts down power until the problem is corrected. Check underneath FIRST to make SURE there is no water dribbling from a small leak. Look for telltale residue trails left from evaporated water on the hoses, lines, motors, etc.
You can enter diagnostic mode by pressing and holding for 2 seconds the POWER, HEAVY, AND DELICATE BUTTONS. All the l.e.d. s will be lit for 2 seconds, then the software version will be displayed in binary code by the blinking of the WASH, DRY, CLEAN, AND CHILD LOCK l.e.d. s. Next, and this will take some practice, if there are error codes present(sets of blinking lights) you will have to read them to be able to find out where the problem(s) is.
•Press the Heavy + Delicate + Power buttons at the same time for two seconds to enter Service Test Mode.
•All LEDs are displayed for the first two seconds and then Software version will be indicated in Binary Code using LEDS ....Wash / Dry / Clean/Child Lock
•Just like the DMR series you advance through the test next mode by pressing the Normal button . However each test will run by itself (see sequence chart on next page) when test has completed an led will light to indicate test is done and you can then advance to the next test .
•Code list and descriptions located on pp#3. Note: Like the DMR series the codes are displayed during operation or test modes and are not stored in memory.
Service Test Modes & Codes
I hope the following pix are clear enough for you to read, if not I will re-send them! I hope this helps you!
9/5/2015 10:15:53 AM •
Samsung...
Answered
on Sep 05, 2015
My Smsung dishwasher always has suds in the bottom after cycle has completed
Couple of questions?
1. do you have a water softener?
2. what type of detergent are you using and how much?
3. is the detergent HE rated?
To clear out the suds run a cup of white vinegar with 4 liters of cold water and run a rinse cycle. or just put a cup of white vinegar into the dishwasher and run a normal load with NO SOAP... you need to clear the suds from the system to work properly again. the proper detergent to use in most new dishwashers is powder style that is HE rated. and don't use a lot either.
4/9/2015 8:01:30 PM •
Samsung...
Answered
on Apr 09, 2015
Samsung dw does not advance to next cycle
Does it work properly if you advance the switch through the cycles by hand? If yes, the cycles are all fine, the timer motor that drives the timer is bad.
8/15/2014 12:38:42 PM •
Samsung...
Answered
on Aug 15, 2014
Where is the float on my dishasher
he float on all dishwashers is on bottom, inside, where the water sits. It controls the water shut off point. They are usually not removavble for cleaning. You simply wipe around them and make sure nothing has accumulated or lodged underneath that would stop if from floating freely.
6/5/2014 12:59:24 AM •
Samsung...
Answered
on Jun 05, 2014
How do you fix the samsung dishwasher dmt300rss low water sensor
First be sure to disconnect/shut off water and power before beginning. Facing the washer pull it out. On the left side, outside, low, there is the water level sensor. It gets gunked up and trigger lever gets stuck. Clean it out and you will be good to go.
6/3/2014 1:19:10 AM •
Samsung...
Answered
on Jun 03, 2014
