WFF 1201 Drain hose clear back of machine removed
It is a common fault that the drain fails to work in
most machines in a period of time and is the most problematic fault in a
washing machine. In all occasions it is important that your observation is most
important and so is vital to the identification /rectification and solution. If
you have noticed that water has leaked then as the drain hose pump/valve and
fittings are located on the underside of the machine it is important that you
look for possible leaks here. In some cases the drain hose would be clogged at
the drain end to outlet of the house and so there will be back flushing
resulting in overflow to the outside. Also the drain pump/valve can be clogged.
Now remove the drain hose clamps and remove the drain pump/valve, clean the
drain pump/valve, use back flushing to clear off all dirt. Now test using power
to see if this works and can be simulated. When refitting, the hose must be tightened
properly. If the pump/valve does not work even with power then it must be
replaced. If there is intermittent power
to the drain valve/pump then the program controller unit is a suspect. Cleaning a pump:
http://www.youtube.com/watch?v=zKjKi50YBpI&NR=1&feature=fvwp Finally the washer must be placed with a tilt- use a
spirit level- so that all water will drain to the outlet port and thereby there
is no residual water remaining. Replacing the pump on a Bosch machine, please check
this link for tips:
SOURCE: washer will not drain, seems to be plugged
Try using a wet/dry shop vac and see if you can pull water through the drain hose in the back. If you can, duct tape the vacuum nozzle to the drain hose to make a good seal. With the vacuum on, watch the drain hose under the tub. If it collapses, you have a clog somewhere. It may be easier to remove the hoses from the pump, first to see if there is anything stuck in the impeller. It doesn't take much to restrict water flow. If you need to remove the hose from the bottom of the tub, try to get as much water out using the method I mentioned. It may be slow, but as long as it can pull water, try to drain. This will save you from a big mess later. If there is a clog in the hose, all that water will gush out with the hose disconnected. You may want to have a few towels handy. Now...in some models there is a plastic ball valve in the drain hose connected under the tub. This needs to stay there, but may also be jammed with crud. Sand and dirt is notorious for clogging at this point in the drain system. This hose should come off with a simple clamp tightened with a screw. If you go through all the effort and find the lines clear, you may have a failed drain pump.
SOURCE: replace drain hose
yes the back panel comes off easily remove the fill hoses and take out the 15 or so screws around the panel, also depending on the age of your machine it may have a front axcess panel that will aid in getting to the drain pump better. Dont forget to rate my solution as solved if i answered you question accurately....Thanks!!!
SOURCE: Cant remove drain pump cap of bosch washing macine
I just replaced my drain pump on my BOSCH washing machine WFL2060-so almost identical to yours. When I posted my question, I was told that it was a pain to do, that many repairmen refuse to do it etc.... even that the front panel does not come off. Well, I am a fairly petite (by athletic) woman, and very far from being an expert at repairing anything....
I just did it in less than 45 minutes with a screw driver and a pair of pliers (and a bit of common sense). Here is the protocol:
1- UNPLUG your machine
2- drain any water that could be left inside (at the bottom front right, you will find a small door: open it, the filter and the small black hose are there)
3- . put an old blanket on the floor behind your machine and a piece of wood long enough to go across the width of your machine- place it half way to what will be the height of your machine once it lies down on the floor- this will save your fingers in case you loose grip of the machine while tilting it down on its back...
4- tilt your machine back and down on its back: use your thigh muscles as the machine si a bit heavy (if you have a friend help you that will be easier-but I did it alone...
5- remove the bottom front panel (2 screws)
6- above the filter access you will see 1 to 3 screws: take them off
7- from the bottom of your machine, take out the electric plug at the back of the pump's motor
8- using your pliers (and a good grip) loosen the metallic braces that hold the 2 hoses and slide them down along each of the hoses
9- the unit will come off into your hand.
10- replace the unit with the new one
11- screw the unit back
12 plug the wires back
13 reposition the hoses (you cannot go wrong, they are on wither side of the pump)
14- slide the braces back onto the hose+pump outlet
15- tilt your machine back
16- plug your machine
17- you are ready for your load!
AND... you have saved about $200 without the part (I ordered it, paid $49 and was delivered to me within 2 business days!)
SOURCE: miele W1712 washing machine drain fault
Just had the same problem, after Much patience and persistence I found the blockage at the y piece that joins the pump to the outlet hose air trap towards the top of the machine LHS with the top and cover off.
It was clogged solid therefore no back pressure on the top little ball valve (between the air trap and the outlet) therefore no seal therefore norain therefore a drain-fault that persists regardless of a cleaned pump filter.
Hi - I understand you will like to know where to find pump and check for clogs. Try the following steps below and hope it is helpful:
To completely clear any clogs in the washing machine drain you will use a pipe auger (snake). Start at the roof plumbing vent and drop cable to roughly 10 or 15 feet past the actual drain. If there is a clog present, the snake will bring up a chunk of debris. Remove it from the top of the vent and discard.
The drain hose is visible toward the bottom of this washing machine. It is held in place by a clamp or a couple of screws.
Remove the drain hose from the back of the washing machine. This is normally held in place by a clamp or a couple of screws. When a drain backup occurs, pieces of debris can lodge in the hose, causing clogs and odors.
Soak the hose in a bucket of warm bleach water.
Soak the drain hose in a bucket of warm water mixed with 1 cup of bleach. Look to see if the line is free of obstructions. Run a small length of clothes hanger through the hose to clear any hard debris.
Reattach drain hose and connect to drain pipe.
Reattach the drain hose using a screwdriver or pliers. Insert the hose into the washing machine drain. Be sure it is all the way into the drain opening.
Run the washer through a full cycle with 2 cups of bleach added.
Cycle the washer with warm water and 2 cups of bleach. The bleach will help remove any odor-causing particles in the machine and drain hose. Running the washing machine through a cycle will help flush away any remnants of the drain pipe clog.
