The mouse works on another computer i tried and when i take the batteries out and put them back in the light comes on for a couple of seconds then turns off on the back of the mouse
Hi friend , make sure you have install the proper driver of it, if you don't have the driver or you don't know what is the exact driver, then my suggestion is you can install windows 7 operating system then i am sure it will work, or you can check it out by connecting a different computer where windows 7 is installed. make sure the usb port is working fine also.
SOURCE: HP Pavilion tx 1000 Won't Start-Up
I HAVE THE SOLUTION TO ALL THE START UP MOMENTARILY PROBLEMS YOU TURN IT ON FAN RUNS LIGHTS ON FOR A SEC THEN SHUTS DOWN. ITS THE NVDIA CHIP.
IT MAY SOUND DUMB BUT IT WORKED FOR ME OK
GRAB THE RIGHT PALM OF YOUR HAND AND PUT ALL THE PRESSURE ON THE AREA SURROUNDING THE ENTER BUTTON AND PUSH DOWN AND TURN IT ON. IF IT DIDN'T WORK THE FIRST TIME PUT MORE PRESSURE ON THE ENTER BUTTON NOT TOO MUCH TO BREAK IT BUT JUST ENOUGHT AND TURN IT ON. AND UR DONE IT SHOULD BE ON!!!
SOURCE: my acer 5532 touchpad has suddenly stopped
Thanks. The Fn F7 idea did not work, the Enable/Disable toggle in Control Panel made no difference BUT the simple pressing of the TINY finger pointing next to the power button DID work. Duh!
someone please help this its really hard to even use my laptop because the mouse on it is broken
the usb port is fine i used it for previous mouses and i have windows 7 installed right now
