When hit presser foot the machine hums but needle will not go up and down to sew
SOURCE: Needle won't move
Make sure the clutch motor is powering up. make sure voltage toggle switch is on 110v and not 220v. Also rotation set correctly. Independently, make sure the motor runs. With your hands and motor belt disengaged, attempt to turn the handwheel toward you. If it is moving, then make sure motor is running. It handwheel does not turn it could be the machine. Make sure the stitch length dial is set at 2 or 3 and not 0 or 5. That could be that problem as well.
SOURCE: Doesn't sew
Hi emnsam....please update your post with the complete Model Number in it's entirety and I will be able to advise you.
SOURCE: Model 6230- presser foot lifter won't move presser foot
That's the problem seized up use a penetrating oil from the top and work it up and down and it should free up
SOURCE: The presser foot came off Brothers sewing machine
position the foot under the shaft making sure the horizontal pin on the foot is in line with the horizontal groove on the end of presser foot fitting on the shaft. Lower the pressor foot arm and it should snap right on. If not, press it up manually. the directions should be in your manual. If you don't have your manual, you can get it online at www.brother-usa.com
SOURCE: "Lower presser foot" error on SE 270D
This happened to me and I eventually realized that there is a small door flap at the top near the "4" in the threading series that can get stuck open. Normally this flap goes up and down with the presser foot, but if it gets stuck open even when the presser foot is down, tapping it or closing it manually will make the error go away.
