Euro-Pro Fast and Easy 420 Mechanical Sewing Machine Logo
judy Posted on Sep 16, 2012
Presser foot wont raise - Euro-Pro Fast and Easy 420 Mechanical Sewing Machine
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Sep 16, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
44
Points
Have u tried wd 40? and or check presser to see if pin is bent
I can not figure out how to thread my 9120 euro the manual is not clear and I am afraid if I pull ******* the thread I may break something
Page 12 of the manual. **Be sure to ALWAYS RAISE the presser foot when threading the top. Raising the presser foot releases the tension disks so the thread will seat properly. When the presser foot is raised, you should be able to pull the thread. When the presser foot is lowered, the thread is difficult or impossible to pull.**
Euro Pro 9120 Instruction Manual Threading The Machine Preparing To Thread...
1helpful
My machine wont sew it keeps notting underneath
Remove the top thread completely from the machine.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify it is threaded correctly.
Set the top tension at the midway point. Lower the presser foot and test the machine. Tweak the tension until the top and bobbin threads meet in the middle of the fabric.
If the presser foot is not lowered when stitching begins, it will cause a thread mess.
1helpful
In the middle of embroidery how to change Presser foot height on the epic husqvanna
Touch the presser foot up button once to raise the presser foot. Touch again and the presser foot will raise to extra lift position, and the feed teeth will be automatically
lowered to make it easier to get heavy fabric under the presser foot.In embroidery mode, the extra lift makes it easier to insert or remove the hoop.
Here is a link to your manual: http://www.husqvarnaviking.com/SiteMedia/Products/Machines/DESIGNER-EPIC/Manual/Designer_epic_manual_EN.pdf
I need instuctions on using different presser foot for ja nome schoolmate
Please add a comment with the specific model of Janome Schoolmate sewing machine.
Fpr the Janome Schoolmate S-3015, make sure that the needle is fully up and raise the presser foot. Then press the red button on the back of the presser foot holder to have that foot drop off. Set the pressure dial to 3 before attaching the new presser foot. For snap-on feet, align the pin of the presser foot (the horizontal bar in the middle of the foot) under the presser foot holder. Lower the presser foot holder (using the presser foot height lever) until it locks onto the foot.
For the zipper foot, you need to fit the rear pin on the foot into groove at the back of the presser foot holder. Then lower the presser foot holder onto the zipper foot.
These are shown on page 11 (14 of the PDF) of the manual. You can download the manual here: http://janome.com/en/machines/sewing/schoolmate-s-3015/ . The direct link to the manual is http://janome.com/siteassets/support/manuals/school-models/schoolmate3015.pdf .
For the S-7330, you need to again raise the needle and the presser foot. Press the lever towards (it moves slightly up, not down) the presser foot holder. Then line up the pin on the foot under the presser foot holder and lower the presser foot holder onto the foot so that it locks. This is also in that sewing machine's manual, here: http://janome.com/siteassets/support/manuals/school-models/inst-book-s-7330esf.pdf . See page 14 (18 of the PDF).
I hope this helps.
Does anybody know why soon as I turn the machine on it makes a weird noise and the screen says raise needle bar and presser foot. I've tried everything, can anybody help?
Hmm. Raise the foot with the presser foot lever. You have to raise the foot up to get the fabric under the foot in order to see.
Raising presser foot on Janime 2212
http://content.janome.com/userfiles/file/Inst%20book_%202212%28En_Sp_Fr%29.pdf
See p. 10 of the manual.
The presser foot lifter is on the right side of the leftmost part of the machine, towards the back of the machine. Press up to raise it.
My presser foot lever wont move
it sounds like the machine needs to be serviced
I have a singer 4552 (portable) and I am having a prblem getting the zipper foot attached. Also I am having a problem getting the design stiching to work. I can get the red design stiches to work but not...
Hi. Here's how to attached the zipper foot.
To Attach the Zipper Foot
1. Loosen the large screw at the left of the presser bar and remove presser foot (You do not need to remove the screw).
2. Hook the prongs of the Zipper Foot around the presser bar from the back, and tighten the presser-bar screw.
3. If the raised edge (zipper or cording) is to the right of the needle, adjust the Zipper Foot by loosening the thumb screw at the back of the foot and sliding foot to the left of the needle. If the raised edge is to the left, slide foot to right.
4. With presser foot down, check its position by lowering needle into side notch, making sure it just clears the foot.
5. Tighten thumb screw to lock foot into position.
When raised edge is placed to right -- adjust foot to left of needle.
When raised edge is placed to left -- adjust foot to right of needle.
1helpful
How to connect the walking foot for ls-2125i? I have removed the snap on presser foot. Unscrewed the leg so I could screw on the foot. The white piece to the right does not fit on my screw so it just...
Turn power switch to "0"
raise the needle to highest position by turning the wheel toward you(counterclockwise) and raise the presser foot lever
release the foot by raising the lever located at the back of the presser foot assembly
place a different presser foot on the needle plate so that the bar on the presser foot is in line with the slot on the shank
lower the presser foot lever and fix the presser foot onto the shank. If the p foot is in the correct location the bar will snap in you should hear a click or snapping sound let me know if this helped thanks! amy
Presser foot wont raise and lower
Does the presser foot move at all when the machine is first turned on?
Do the needle and feed teeth calibrate when the machine is first turned on?
You probably need to locate your nearest authorized repair center.
Top Euro-Pro Sewing Machines Experts
Mike Cairns
Mike Cairns
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
