It seems like there is still water that I can't see in the drum. I tried starting cycle over, but washer doesn't respond at all, It tried unplugging the unit to get it to reset but nothing happens with the washer, they dryer still works fine though. The unit is fairly new, it seems like it just needs to be reset, but I can't figure out how to do it.
SOURCE: Front load Frigidaire Gallery washer
You are having a door switch problem change it out and you will have a new washing machine.
SOURCE: frigidaire front load washer model LTF530DS loose drum
I have the same issue with the broken spider...in the us and they say it is $300 for labor and $360 for parts. My washer is only 3+ years old...what can I do?
SOURCE: frigidaire affinity front loading washer won't drain
HI .THANKS FOR YOUR QUESTION. THE PROBLEM IS WITH THE WATER PUMP.REMOVE 2 SCREWS AT BOTTOM OF FRONT PANEL . PUMP ON RIGHT .REMOVE HOSES AND CLEAN OUT THANKS THE APPLIANCE DOC.
SOURCE: Frigidaire Washer Dryer Combo: Dryer Only works on washer spin
Are you connected to a 30 amp breaker w/ 30 amp wire?
SOURCE: frigidaire washer model #fwt425rhso
This is the second time I have had to replace the drum/support shaft on this washer. Not only is it expensive, but very difficult to replace. Probably the very worst washer on the market for this reason. And I only do 3-4 light loads of laundry per week. A definate design flaw on the part of the manufacturer.
Hello Mike Brady - From what you have described it seems like the dryer is experiencing a wiring failure or a communication error with the control board. Contact a professional to move forward accurately.
