With the tv off press and hold the volume down button on the tv & clear button on the remote for 5 to 7 seconds. perhaps you can borrow a friends remote for a day to fix it. good luck.
For the RCA Television Model 27F530T, the way to reset parental control password is to do the following:
Have the TV turned off. Press and hold the Volume Down button on the TV
(one of the six buttons on the tv) and the Clear button on the Remote.
Keep them held down until the TV turns itself on. Then the password has
been reset. You can access the menu through the remote by pressing
Menu, and highlighting the Parental Controls option, then pressing OK
to access it. The interface will prompt you to create a password.
This is the absolute way to do this. I am posting this because repairguy fixed my problem with this, and there are so many non-working solutions out there. This is the one that absolutely works for a RCA Television Model 27F530T.
I tried the remedy above, but it wont reset, i tried this multiple times, TV comes on, and i go to parental controls, and it says improper password. What now?
Kekitowong
does this hold good for model F27227EM as well. Its a old 27" from RCA and has a parental lock in channel 3. As am unable to unlock this am unable to use the set up box which is hooked to channel 3.
I dont have the original remote
Please help
You should be able to use the front panel controls on your set and find the locking function and un-lock it from there. Stargazer
1. Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
2. Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
3. Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
4. Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
5. Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
OK.
Same problem, tried for an hour to reset, it wont let me reset the password, any other suggestions?
i dont have a *clear* button on my remotes, whats another alternative?
I DON'T HAVE A RCA REMOTE, JUST A UNIVERSAL WHICH HAS NO CLEAR BUTTON ON IT. ANY SUGGESTIONS?
THIS IS VERY FRUSTRATING!
