20 Most Recent Sony FD Trinitron WEGA KV-36FS120 36" TV Questions & Answers
My sony tv has sound but no picture and red light keeps blinking
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ Type in the brand name of your device [exclude the model number] at the search box at the right column to get gathered related posts. Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location
3/27/2022 1:47:34 PM • Sony FD... • Answered on Mar 27, 2022
2answers
Sony KV blinking red light
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. https://elektrotricks.blogspot.com/ http://electronicshelponline.blogspot.com/ Type in the brand name of your device [exclude the model number] at the search box at the right column to get gathered related posts. Blinking codes details to many popular brand TVs are given. If blinks continue without any pause, the main board is faulty. Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.....
3/27/2022 1:45:25 PM • Sony FD... • Answered on Mar 27, 2022
0answers
I have a 1997 soney tv turns on but red light flashes 6 times i have replaced the lamp but still does not turn on
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/ If blinks continue without any pause, the main board is faulty. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
5/27/2016 7:18:53 AM • Sony FD... • Answered on May 27, 2016
Continuous flashing red light on sony trinitron television
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electro-medical.blogspot.com/
5/21/2016 7:57:06 PM • Sony FD... • Answered on May 21, 2016
How to autotune channel when channel is locked?
Refer its user manual for details. http://electronicshelponline.blogspot.com/
4/15/2016 6:45:47 AM • Sony FD... • Answered on Apr 15, 2016
No sound on one station
try to adjust in remote control the fine tuning or if there is a system in audio you can try it also.
1/10/2016 11:47:24 PM • Sony FD... • Answered on Jan 10, 2016
Why is it going black every 3 seconds then back on in 3 seconds?
Check and replace damaged component/s at its horizontal scan output section circuit.Check the LOT (Line Output Transformer) too for damage.Replace the horizontal scan output transistor.Check the input voltage to LOT.If the voltage is absent check the feeder resistor; if any.If you wish to get some details; check the site linked here.Surf the site with patience.Pull up older posts. http://electronicshelponline.blogspot.com/ Type in this key phrase " my service table today " in the search box at the top right of the display window, to get gathered some pages which has the details of practical experiences to the author of that site.
9/18/2015 6:13:36 AM • Sony FD... • Answered on Sep 18, 2015
Why doesn't it show full screen?
When you unplugged it you removed power and the memory setting for full screen was wiped out. Go into your menu for screen size controls, reset, and all should be fine.
9/7/2015 1:38:27 PM • Sony FD... • Answered on Sep 07, 2015
Small screen inside of screen
I think you might be referring to what's called, 'picture in picture (PIP). Its a feature of the TV that allows one to see what is on other channels while your current channel stays on the screen. Refer to your manual of how to disable, or if no manual, play with the remote to see what button eliminates it.
2/18/2015 2:36:13 PM • Sony FD... • Answered on Feb 18, 2015
3answers
Sony TV stuck in stand by mode
the 9 blink code is caused by a bad diode on the pc board. The zero crossing detect circuit is not allowing the power supply to come on .
2/4/2015 3:37:55 PM • Sony FD... • Answered on Feb 04, 2015
2answers
Sony tv model # kv36fs320 no picture sound is
The power seems ok as it was working fine this morning had kids channel on for my daughter for about 1-2 hours while I was pottering about cleaning then daughter told me TV had gone black
12/7/2014 9:16:05 AM • Sony FD... • Answered on Dec 07, 2014
Can you leave your Sony wega on 24/7
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
12/4/2014 3:13:24 AM • Sony FD... • Answered on Dec 04, 2014
My picture is displayed in the top right corner. how do I get it back to full screen
Sounds like 'Picture-in-Picture' is interfering. You can try pulling the AC plug for an hour or two to 'reset' ii of check the user guide for operation:
10/23/2014 11:21:08 PM • Sony FD... • Answered on Oct 23, 2014
Hi my tv slipped and fell against the stairs
If u move the tv pictures come back on clear and good,no bruses to the pictures at all?Yes,this tv can be fix the PCB main board is cracks or borkens,could be mend to it by steal rods and solder joints by a tv tech. to fix it.But if the pictures have bruses in it.The tv picture tube is damage,sorry this tv garbage,not worth fixing.
10/23/2014 11:06:46 PM • Sony FD... • Answered on Oct 23, 2014
Sony FD Trinitron WEGA KV-36FS120 36" TV Logo
524 questions posted
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Sony Televison & Video
Most Popular Question
sony tv model kv36fs320 no picture
  • Televison & Video
