20 Most Recent Jensen TS2750J TV Questions & Answers
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jensen TS2750J... | Answered on Apr 26, 2016
does anyone know the codes for a mirai tv for a universal remote
Jensen TS2750J... | Answered on Jan 12, 2016
My Advent TV did the same thing. Blue Screen with a red lock in the upper left corner. Just press and hold the display button for about 10 seconds. It will clearn
Jensen TS2750J... | Answered on Oct 27, 2014
0028,0022. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Jensen TS2750J... | Answered on Oct 12, 2014
Check and replace damaged components; or, check for any loose solder terminal/s at its vertical scan output section circuit. Gopakumar Gopalan Google
Jensen TS2750J... | Answered on Feb 24, 2014
0516 0658 0502 0513 0684 0753 0541 0673 0195 0456 0601
0514 0193 0214 0054 0720 0533 0699 0361 0616 0338 0209. Try these codes. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
Jensen TS2750J... | Answered on Feb 15, 2014
260,266,268. Try these codes. If you wish to get more, try the following links. Both the sites linked have set-up code list & set-up procedure to many popular brand remote controls. Surf the sites with patience.
Jensen TS2750J... | Answered on Jan 26, 2014
Codes to check with Lexsor are 0045,0028,0046,0082,0018. If you wish to get more setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts. Setup code list and proceedings to some popular model remote controls are given.
Jensen TS2750J... | Answered on Mar 05, 2013
Check and replace damaged component/s in its main power supply regulator section circuit. Contact any experienced service technician.
Jensen TS2750J... | Answered on Oct 11, 2012
Hold down the DISPLAY button for 4 seconds. Voila!
Jensen TS2750J... | Answered on Oct 09, 2012
Check its speaker. If it is found OK, check and replace damaged component/s in the audio output circuit inside.
Jensen TS2750J... | Answered on Oct 04, 2012
Many Jensen TVs have a parental lock that can be set to stop children from watching certain television shows or channels. In order to activate or deactivate the controls, you have to know the four-digit code or parental lock passcode. If you forget the passcode or if the lock gets set accidentally, you can still unlock the TV.
Turn on the TV using the remote control. In most cases, you will need the original Jensen remote to unlock the TV if you aren't sure of the unlock code. You can purchase an original replacement online if necessary.
• Look at the screen. If you see a red key on the bottom of the screen, press "Function" and "Mute" on the remote at the same time. This will unlock the channel. Do this if you want to bypass the lock to watch a certain show or channel while leaving the TV locked. All other channels will remain locked and the TV will lock again when it is turned off.
• Unlock all of the channels on the TV by entering 0711 or 3308. These are the Jensen factory reset codes that will reset the TV to the original factory settings. By doing this, you will loose any information that you have stored in the TV, such as channel labels and schedules. You will have to program the TV again by going through the entire initial set up.
•Call the technical support service number in your owner's manual if neither of those codes work. A technician can help you troubleshoot the television as the problem may not be the parental lock feature. Have the model number and serial number of the TV available when you call.
• Take your television to a TV repair shop if neither of the codes work and the TV locked by itself while it was turned on. In this case, the TV may need to be rewired
Jensen TS2750J... | Answered on Sep 19, 2012
Well after spending about 45 mins on hold and searching the internet for the last 2 days the resolution to this issue is to hold the display button down for 3 secs .... Yep thats it Hope this saves someone some time --Brian
Jensen TS2750J... | Answered on Jul 13, 2012
This can be the MAIN power supply in the protect MODE as it is possible that there is a short within in the driver sections. You need to be equipped to check as it involves isolating the circuit, check the + B to the related circuits . Check the SMPS, remove the connections to the main board and see if the voltage build up . If so you cane proceed to isolate the circuit which seems to short the power supply. check for heating components which can indicate a fault.
Jensen TS2750J... | Answered on Oct 29, 2011
Televison & Video Logo
111 questions posted
Top Jensen Televison & Video Experts
Jaime Hernandez
Are you a Jensen Televison and Video Expert? Answer questions, earn points and help others
View Most Popular
  • Jensen Televison & Video
Most Popular Question
mirai tv remote control set up code
  • Televison & Video
