20 Most Recent
Toshiba 20DL74 20 in. EDTV-Ready LCD Television Questions & Answers
Mw27h62
X-box
Sounds like it could be a bad inverter board, Toshiba p/n#72001911 and they cost about $35
plus shipping... This is a common failure with this model causing anything from intermittent shutdown to simple loss of video.
Get it in the shop and have them check it out. Might also take the part number with you so they don't have to research it...
Good Luck
Bill
CAN NOT GET CABLE CHANNELS
Yep! I agree - your tuner on the TV is not made for Digital reception.
You will still need to use the Verison Cable box to view any channels.
The newer TV's have the digital Tuners built in. Note: Plasma's are faster locking on to channels than LCD's.
Blessings,
A/V Media Guy.
Tv wont start up!
Power supply issues I bet.
A good servicer can replace or repair.
Blessings,
A/V Guy
Toshiba TV will not turn on ....
First off! Is it still under warranty?
If not my thoughts is either one of two things,
1) a bad or problematic power supply
2) the lamp ballest 'florecent tubes' for back lighting is going bad or bad.
Blessings,
A/V Guy
Parental controls
First try seeing if your dvd has a options button on the remote.If it does you may be able to find the specific choice that lets you reset it.Otherwise try turning on your dvd and having it run without a disk in it.A dvd menu itself might show up and give you options.
TV WONT TURN ON
If it's less than a month old, you shouldn't have taken off the back. I subjest taking it back to where you bought it from and get it exchanged or get a refund.
Toshiba 20DL74...on/off
I had the same problem with mine and I finally figured out it was the power supply. I ordered a new generic replacement and I have'nt had a problem since other than a few noise lines in the lower channels and that might be because I didn't buy a Toshiba replacement which may have a filter in it. It has not shut off now for over a year.
TV loses all power
I had same problem. Finally figured out the power supply was the problem. I ordered a generic replacement and it hasn't shut off again for over a year. The only thing I have notice is there are noise lines in the lower channels (1-6). This may be beause the Toshiba power supply may have a noise filter in the power supply. But the generic was $30 compared to $80 Toshiba
