Hitachi washing machine SF-150 GJX
SOURCE: Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
SOURCE: washing machine model no SF-160GJ
it
will not let you unlock the door because the machines full of
water?--the machine will not finish its cycle because the vacume switch
is still detecting water. The water will not drain because the pump is
blocked with something , probably a wire from your underwire bra, all you
can do is undo a pipe undernieth and let the water drain away and take
the pump to bits? There may be an inspection cap somewhere on the front
at the bottom.
Hope helps.
SOURCE: Hitachi SF-P95FJ WASHING MACHINE ERROR
if you have Hitachi nw-d8ax f1 error check water sensor
f3 error check rinse filter f9 error do not know where the error but I did repaired, remove back panel and right hand side inside polithine cover find blue connector its with 2 wires remove it and switch machine it will give f3 error with sound reconnect the socket its started working
mail me if yours working I will give you more tips [email protected]
cheers
