I brought a sharp 32 inch color television 32c241 @ best buy less than a year and the tv cut off and will not cut back on. What should i do? Are there any recalls on sharp 32 inch color television 32c241. Since, it has been a problem with sharp 32 inch color television 32c241 from other customer since 2005
my sharp 32c241 won't turn on unless I unplug it for awhile and then turn it on but once on theres no telling how long it will remain on. It turns off and won't come back on without doing the above. It worked for months but all the while it would turn off then back on immediately until one day it turned off and wouldn't come back on and I had to call tech support.my sharp 32c241 won't turn on unless I unplug it for awhile and then turn it on but once on theres no telling how long it will remain on. It turns off and won't come back on without doing the above. It worked for months but all the while it would turn off then back on immediately until one day it turned off and wouldn't come back on and I had to call tech support.
AnonymousMar 22, 2014
la tv solo enciende y se apaga de imediatola tv solo enciende y se apaga de imediato
AnonymousMar 31, 2014
Plug it in, hit power, nothingPlug it in, hit power, nothing
You can't post conmments that contain an email address.
There is no recall on sharp tv that i know about if your tv is still on warranty take it back to the supplier.if the warranty is finish call a tech the tv has a problem in the power supply and related circuit.good luck.
If there are lines on the screen [parellel lines across the screen horizontally, at about an inch or so apart], your tv needs screen adjustment. Its screen voltage is now high. It can be brought low by adjustments. There is a screen adjustment control, usually integrated with Line Output Transformer. If you know, you yourself can adjust this. It is an internal adjustment and need to open the back cover of the TV. Don't use your TV for long time without rectifying this problem. It may get picture tube damaged. The electron guns inside the picture tube neck will get red hot and its emmision will be reduced.
Ur LCD backlight inverter board is dead.Replaced this inverter backlight board will get ur picture back.Tries Shopjimmy.com,Ebay.com to buy the refurbish LCD inverter backlight board.It a long board sharp.
Unplug TV set from the outlet, wait 30 seconds, plug it back in, select right input with your remote if you using cable box or Punch the channel that you want to watch if you have cable service connected directly to the TV.
The street value would be 100-150 dollars. If TV is a cheap model or abused or very used, you should pay less. Consider a Sony or a Toshiba in tube style since all are cheap now.
Contact Sharp to locate the nearest authorized Sharp servicer. Sharp Aquos servicers have to give Aquos TV top priority. Sharp provides very good and fast serice on these sets.
This is a power supply problem. It may be as simple as a blown fuse or as complex as a problem with overvoltage and overcurrent events within the circuitry of the Horizontal and Hig Voltage sections of the set. If it is a fuse that's simple to replace, the other well that can get kind of involved. In any event I would suggest that you get the set analyzed by a qualified Television repair person.
