Hi I also post in here , so that you can let me know how it goes.
Try unplugging the transmitter from power adapter, if it also has batteries remove them. Also unplug transmitter audio cable.
Then remove batteries/unplug adapters from speakers.
Wait few minutes and reconnect the system.
This is a proper hard reset, and can fix minor problems.
If when you re connect the transmitter does not glow, or you do not have sound on one or both channels then there is a fault.
Check the transmitter audio cable, a short in there can cause troubles.
If you find no problems , then unit is defective, as it is under warranty contact Acoustic Research to validate the warranty here and get the transmitter or the whole set replaced.
http://www.acoustic-research.com/homedecor/HomeDecorInfo.do?ACTION_TYPE_ID=ACTION_TYPE_CONTACT_INFO
Thanks! That did it.
I've purchased a set of Sharper Image wireless indoor-outdoor speakers with a transmitter last year. I love the speakers and everything was working fine until the transmitter went out the other day. First the red (power light) was blinking so I went to check if the transmitter is plugged in correctly, I checked the cord to make sure it wasn't loose and that's when the transmitter lost power connection for good. Is there a way to take it apart and fix it or is there a genetic transmitter that I can buy for the existing speakers?
