HP Photosmart C3180 All-In-One InkJet Printer Logo
Posted on Dec 18, 2008
Want to print 2 wallet size on 4x6 photo paper
My HP Photosmart 3180 used to let me print 2 3x4s or 2 wallet size on a 4x6 photo paper. Now, all of a sudden, it will only let me print one per 4x6 paper. I haven't changed anything as far as I know. Is there a solution? Thank you
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 20, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1894
Points
Under print options it will pop up a menu saying to "only show options compatible with my computer...." unclick that and it will allow you to select letter size paper again
Trying to print a 4 x 6 photo with HP Photosmart 130 I'm trying to print a 4 x 6 photo with HP Photosmart 130 printer, from my desktop HP Photo & Imaging software. It prints all but last 1/2...
It is for sure a matter of settings ..so you have to select the paper type ..and the dimensions ..and also the position ...landscape or portrait ...and after that go for the print..Also select the paper type and size in the printer if it has the feature for it ...It is safer to select there too ..cause from computer you have to make it each time and you may miss something ..
If it is still making problems ..just reinstall the printer 's driver and software from scratch ./..(remove the old one ..and reinstall a clean version of the software ) This way you will be sure it is not an software error..
Efforts to print 4x6 borderless print result in only top part of photo paper being used and top third of photo being cut off
First thing to try (and I'm assuming you're attempting to print a photo within HP Image Zone & have already selected the 4x6 photo tray? Hint: can be done via printer, properties, printing shortcuts) is to change the 'more options' directly below where you'd selected the 4x6 image size and then change to 'shrink to fit' vs. the default 'crop to fit'... Additional thoughts includes rotating the image (can be done directly on the preview screen...)
Printing 4x6 photos with photosmart express - prints only 4x5 image on 4x6 paper
Hi
the photo printing settings will need to be changed on the PC to either the correct paper size or change the paper size to match the size of the print out
When I print pictures on the 3210 HP all-in-one, they come out very small even though I choose the 4X6 in paper size for the photo tray. I've tried everything I can, but the pictures keep printing wallet...
First thing that comes to mind is that a 4x6" print could print four wallet sized photos; be shure your are not printing more than one copy.
If you are trying to print more than one,it will print the actual picure you have and leave space for the number of other nonexistent prints selected.
See page 75 of the Manual. for directions on how to set up photo printing.
If you have photoshop, you can resize your documents using the menu item, Image / Image size, (Alt + i then i again)
Set the resolution to 300, then the document size width to 6 or 10 inches.
This will guarantee that your document is full size, (though the printer should be able to resize it to fit on the page no matter what).
Give these a try. It's really a shot in the dark, but it's my best guess.
Cheers.
Richard.
1helpful
I have a photosmart 8250 using iphoto, how do I print 3x5 using 3x5 tray?
Set the default printer driver settings to print 10 x 15 cm (4 x 6 inch) photos
  1. Make sure 10 x 15 cm (4 x 6 inch) photo paper is loaded into the photo tray. NOTE: The Photo Tray light on the printer does not have to be lit when printing from a computer.
  2. Click Start and then click Control Panel .
  3. Click Printers and Faxes .
  4. Right-click the icon for the HP Photosmart 8200 Series and select Printing Preferences .
  5. On the Paper/Quality tab, select 4x6 or 4x6 with tab from the Size is drop-down menu (under Paper Options).
  6. Make sure that the Source is box is set to Photo tray .
  7. Click the Borderless Printing box if borderless prints are desired.
  8. Click Apply and then click OK .
  9. Open the software program you wish to use and set up the pictures you want to print. Make sure to select a 4x6 inch layout for the photos within the software program before you print from the software program.
I want to print wallet size picturws on my canon picture printer...how do i do that?
The printer can only take 4x6 paper, so you have to choose wallet size in your printing software and print 2 on a page and then cut them out.
Hp photosmart 3 n 1 printer
Your software sholud let you select wallet size and print multiple copys on a standard size of photo paper.
Printing from iphoto - photos are not 4x6 and not borderless
wat pc do u have? are u using mac? if ur using microsoft try these:
go to ur printer and faxes - right click on ur hp printer icon - select preferences - select printer shortcut tab - select the appropriate size - the click ok. that should solve ur problem
Reprinting photos
try using a ruler to check if you have the correct paper size.
open up HP Solution Center verify the printer settings..
use borderless printing, paper size 4 x 6.
k24674
Grand Canyon Tech
Grand Canyon Tech
