20 Most Recent HP Photosmart C6100 All-In-One Printer Questions & Answers
HP Drucker zeigt Fehler 0xc18a0206
HP Drucker zeigt Fehler 0xc18a0206 an. - HP Photosmart C5180All-In-One Printer
11/3/2020 9:34:30 AM • HP Photosmart... • Answered on Nov 03, 2020
2answers
I don't understand the my printer was working perfect it pass the aliment but I turn off the printer for few weeks and now when I turn on my printer it won't print black it won't pass the
Try removing printhead and soak it in a window cleaninig solution for a few hours or overnight. We made instructions on how to remove printhead in the video below:
1/30/2019 5:38:50 PM • HP Photosmart... • Answered on Jan 30, 2019
Hp C6180 all in one will not connect to wireless laptop
when the printer is on is there on your pc/laptop a wifi signal checking your wifi signals. then using the wifi code off the printer put the code in and connect. and then the printing should be allowed. and that laptop/pc is the controler. i had to do this with mine and its been fine since.
11/28/2017 1:23:37 AM • HP Photosmart... • Answered on Nov 28, 2017
Never used HP c6100 keeps cycling. Starts as soon as it is plugged in without touching the power button.
Hi, Try unplugging all the cables from the printer(power and data cables). Press and hold the power button for 10sec(it will do nothing since its not plugged in. We are trying to remove the static electricity from the machince, if there is any). Repeat the same process once more. Now plug back all the needed cables and check.
3/21/2017 5:11:42 PM • HP Photosmart... • Answered on Mar 21, 2017
Printing 4x6 photos with photosmart express -
Hi
the photo printing settings will need to be changed on the PC to either the correct paper size or change the paper size to match the size of the print out
1/28/2017 2:22:13 PM • HP Photosmart... • Answered on Jan 28, 2017
Printer won't pick up paper to print or copy. paper is loaded put registers as 'out of paper, load paper face down in main tray'. this has all been done. What's wrong
If it's in the 1st paper tray, pull out the tray and check if theres a sensor. Check if it's out of position, if it is, place it back in position. If the printer still says 'load paper' the sensor is most likely faulty.
12/18/2015 11:01:13 PM • HP Photosmart... • Answered on Dec 18, 2015
0answers
How do I change from high resolution printing
from the properties of the printer
9/28/2014 10:35:16 AM • HP Photosmart... • Answered on Sep 28, 2014
Hp c6150 error 0xc18a0106 printer error
Ve aqui http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00489814&cc=us&lc=en&dlc=en&product=3560275&tmp_track_link=ot_search
8/23/2014 9:04:41 PM • HP Photosmart... • Answered on Aug 23, 2014
When i scan one half of the scan is black, the other half is white
it's a cable error unfortunately you must change the cable inside the scanner.
4/8/2014 8:52:40 AM • HP Photosmart... • Answered on Apr 08, 2014
2answers
I am trying to fax something but am not getting a
you would be suprised how many people use the wrong port there usually are two on a multifunction printer scanner copier fax machine check to see if there are on yours and use the other port.
3/18/2014 3:48:38 PM • HP Photosmart... • Answered on Mar 18, 2014
HP Photosmart C6100 All-In-One Printer Logo
280 questions posted
k24674
Grand Canyon Tech
Grand Canyon Tech
View Most Popular
PhotoSmart HP
  • PhotoSmart HP
Most Popular Question
c6100 error oxc19a0035
  • Office Equipment & Supplies
