This printer went from rainbow dusting across the entire page, no print visible. after cleaning and inspecting the printer and re-installing the toner carts, i get diagonal bars across the page in color no in black print. when i look in at the toner units the toner mag roller has candy cane stripes of toner in the cyan, yellow. replaced black, it was out, replaced cyan, had no yellow at the time. cyan still looks like striped mag roller. any thoughts
I have a 6180N and when my colored pages come out they have what looks like a small banner in CYAN going across each page horizontally in some form or step and repeat fashion, It is mainly on the left side of the page but is also lightly on the right? I have no error messages and total page print count is 3222. Any ideas? This was new in 09 when I got it. ThanksI have a 6180N and when my colored pages come out they have what looks like a small banner in CYAN going across each page horizontally in some form or step and repeat fashion, It is mainly on the left side of the page but is also lightly on the right? I have no error messages and total page print count is 3222. Any ideas? This was new in 09 when I got it. Thanks
AnonymousMar 26, 2014
How do I get the printer to respond to the print command?How do I get the printer to respond to the print command?
AnonymousMar 27, 2014
When I print only black sometimes cyan toner droped on the top of the paper ... :-( Could you help me ?When I print only black sometimes cyan toner droped on the top of the paper ... :-( Could you help me ?
You can't post conmments that contain an email address.
Dell printers provide the best print quality and efficiency amongst its competitors in the market. But, issues are very common to occur as no matter how advanced the technology is, some problems are always there. Users could get in touch with the experienced technicians at Dell Printer Support Number for the instant solution to their problems. Well qualified technicians and highly experienced professionals with excellent customer handling skills are present to assist the users. Technicians are certified from reputed organizations to provide quality Dell customer service.Dell Printer Customer Care Number +1-833-260-7367 https://easysupportnumber.blogspot.com
Print Quality Problems on 3010cn. Reset the NVRAM On the 3010cn
To reset the NVRAM, perform the following steps:
Press the Menu button.
Press the (down arrow) button on the printer until Configure
appears, and then press the (right arrow) button on the printer or (Set) button.
on the printer until Madiagonal lines on print - right%20arrow%203100cn.jpgrs, and then press on the printer or .
Press the until Initdiagonal lines on print - return%20arrow%203100cn.jpgand then press .
Press Initializing and Restart Printer will appear.
Power off the printer and power back on.
To print the Gradation [ESS] test print, perform the following steps:
Power off the printer.
Hold down the up and down arrow bdiagonal lines on print - return%20arrow%203100cn.jpgower the printer on. This will bring up a Customer Mode menu.
Press the down arrow button until Test Print appears and press diagonal lines on print - return%20arrow%203100cn.jpges/return%20arrow%203100cn.jpg" alt="return%20arrow%203100cn.jpg" class="h_mi" /> button.
Gradation [ESS]
appears and press the button.
Press the button. On the LCD, Processing appears and the test page is printed.
To print all four 20% toner test prints, perform the followdiagonal lines on print - return%20arrow%203100cn.jpgclass="h_mi">Power off the printer.
Hold down the up and down arrow buttons on the printer and power the printer on.
diagonal lines on print - return%20arrow%203100cn.jpgdown arrow button until Test Print appears and press the button.
Press the down arrow until Cyan20% [ESS] appears and press the Press the Press the Cancel button.
Press the down arrow until Magenta20% [ESS] appears and press the button.
Press the button. The test print will print.
Press the down arrow until Yellow20% [ESS] appears and press diagonal lines on print - return%20arrow%203100cn.jpges/return%20arrow%203100cn.jpg" alt="return%20arrow%203100cn.jpg" class="h_mi" /> button.
Press the down arrow until Black20% [ESS] appears and press the button.
Reseat the drum cartridge, perform the following steps: diagonal lines on print - lift%20drum%20cartridge%20lever%203100cn.jpger.
Unplug the power cable.
Pull to open the front cover and then lift to open the top cover. (Figure 1)
Figure 1 - Open Front and Top Covers
Raise the lever on the top right side of the drum cartridge. (Figure 2)
Figure 2 - Raise Lever to Release Drum Cartridge
Grasp the drum cartridge by the handle and lift up and out. (Figure 3)
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below: 1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab. 2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page. The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps. If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below: 1. Please open the "Solution center" again and go to the "Maintenance" Tab. 2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer. 3. Get a damp paper towel. 4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds. 5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. 6. Next dab the cartridge on the towel to make sure that the ink is flowing. 7. Snap the cartridges back into the printer. 8. On your computer, select "Old Cartridge install." 9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Possible print alignment issue. Check the toner and then go to properties of printer. Clean heads etc and then print test page. Wizard should assist to troubleshoot
Your balck ink printhead is clogged with buit up ink. Manually clean it with cotton buds and proper cleaning solution, right doen where cartridge sits and the contact area the ink part of cartrigde contacts. Try printing now. Did you reset ink levels too?
