20 Most Recent Dell 1720dn Laser Printer Questions & Answers
Open the back cover and look for paper wrapped around a roller back there. That is the most common cause of the issues with this machine. The other thing you can try is to push down on the little flaps where the paper comes out of the printer. These get stuck and need cleaning/replacement all the time in the later life of these models (1720's).
Dell 1720dn... | Answered on Jul 18, 2019
If the paper intake rollers are slick and grab paper on an angle, the feed causes the paper to move off center. Rubbing the rollers with a cloth and rubbing alcohol will clean them. Slightly rubbing the entire roller with a fine abrasive material can help with the paper path issue.
Dell 1720dn... | Answered on Feb 07, 2018
  1. Turn off the printer.
  2. Open the front cover.
  3. Press and hold the Continue button continue_button_0.jpg as you turn on the printer.
    All the lights cycle.
  4. Release the Continue button continue_button_0.jpg.
  5. Close the front cover.
    The light sequence representing the Home menu is displayed.
  6. Press the Continue button continue_button_0.jpg until all the lights cycle.
    The Printer Settings Configuration sheet prints.
Dell 1720dn... | Answered on Feb 24, 2017
What is the problem? Any messages?
Terry
Dell 1720dn... | Answered on Mar 03, 2015
Change your toner cartridge. A properly working toner cartridge will never leave that much toner lying around. The white lines are an indication that either the toner is low, or the mag roller is defective.
Dell 1720dn... | Answered on Dec 05, 2014
First of all dirty rollers are not the cause of your problem as long as the printer is picking up the paper.
Black marks or streaks on a DELL 1700 series printer are usually caused by the drum assembly which, in this model, is separate from the toner cartridge. There is no repair, you need to replace the drum assembly and perform the drum reset procedure. In very rare cases a buildup of residual toner on the fuser can cause marks as well, but I have never seen this on a DELL printer.
To replace the drum:
1. After removing the paper tray, open the front of the printer.
2. Remove the toner cartridge by pushing down on the black release tab and pulling the toner up and out of the printer.
3. Pull the drum assembly straight out of the printer using the blue plastic handle.
4. Carefully unpack the new assembly and install in the printer. Be careful not to touch the photo-sensitive roller underneath.
5. Reinstall the toner cartridge, close the printer and insert the paper tray.
6. Perform the drum reset procedure exactly as follows:
power off and open front door hold down the continue button as you power on printer leaving front door open when error light comes on release continue and close front door. toner low, load paper, ready, and continue will all be lit. press cancel slowly 4 times or until just toner low lights up. each time you press cancel, the light sequence should change when just toner low is lit, press and hold continue button until lights cycle up and down in sequence. release continue.. toner low will be lit again turn printer off, wait 10 secs or so and then back on press continue button to print off settings page and check under cartridge information, photoconductor value is 0K (zero)
Dell 1720dn... | Answered on Aug 11, 2014
Paper Tray Rollers Step 1 Turn off and unplug your HP printer. Pull out your printer's paper tray and locate the printer rollers on the paper tray. Each roller is gray or black, and they are made of rubber. Remove the rollers from the tray.
On HP inkjet printers, the printer roller is not on the paper tray; it is on the area inside of the printer where the paper tray slides into the unit. Remove the paper tray and sit your HP inkjet printer upright, so the paper tray area is facing upward, and then look for the printer roller.
Step 2
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the paper or internal tray rollers with the cloth. Fold the cloth in half and repeat the cleaning process until the rollers are free of dust and debris.
Step 3
Wipe the rollers with a dry, lint-free cloth to remove any remaining dust or debris. Let the rollers dry completely before sliding the paper tray back into your printer.
Internal Pickup Roller - Laser Printers Only Step 1 Turn off and unplug your HP printer. Open your printer's front door and pull the printer's toner cartridge toward you to remove it from the printer.
Step 2
Locate your printer's internal pickup roller. The roller is gray or black, and it is made of rubber. Lift the roller upward, towards the front of your printer. Pull the roller gently out of the printer and lay it on a clean surface, such as a desk or workbench.
Step 3
Pour 1 tbsp. of isopropyl alcohol or clean water onto a lint-free cloth and scrub the pickup roller with the cloth. Fold the cloth in half and repeat the cleaning process until the roller is free of dust and debris.
Step 4
Wipe the roller with a dry, lint-free cloth to remove any remaining dust or debris. Let the roller dry completely before snapping the pickup roller back into place inside of your HP printer. Reinstall the toner cartridge and close your printer's door.
Press and hold the Continue button as you turn on the printer - all the lights will cycle
Release Continue button and close the front cover
Press the Continue button until the lights cycle and the configuration page will print
Dell 1720dn... | Answered on Jul 01, 2014
The drum has come to the end of its life. You should replace the drum assembly and reset the drum counter. Here is the procedure:
Dell 1720dn... | Answered on Jun 02, 2014
Check that there are still two rubber bands around the two little rollers. One of mine fell off and got stuck inside.
Dell 1720dn... | Answered on May 28, 2014
Any time an imaging drum is replaced on a 1700, 1710, or 1720 model dell laser printer, you must reset
the photoconductor count. The following procedure illustrates how this is done:
1. Open the front access cover
2. Press and HOLD the Cancel Button (Red X)
3. When you see the LED's 'Chase' turn the printer off
4. Close the access cover, and turn the printer back on
5. Press the Continue Button (Green Triangle) to print a settings report
6. Under the section 'Cartridge Information', locate the item 'PHOTOCONDUCTOR COUNT=0K' indicating 'Zero Thousands'.
s now been reset, and you should now be able to print now ok
Dell 1720dn... | Answered on May 15, 2014
Dell 1720dn Laser Printer Logo
282 questions posted
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Ekse
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
  • Dell Office Equipment & Supplies
Most Popular Question
dell 1720dn mono laser printer not
  • Office Equipment & Supplies
