20 Most Recent Xerox Phaser 7760/YDX Laser Printer Questions & Answers
Workcentre 7345 code 004-363
004-363 PLZ HELP MI
8/6/2018 3:08:07 AM • Xerox Phaser... • Answered on Aug 06, 2018
White streaks on Cyan color
This to me seems like the developer tank problem. Call for service
1/25/2018 3:00:10 PM • Xerox Phaser... • Answered on Jan 25, 2018
0answers
Upon startup fault 004-350 occurs
faulty ROS unit or ribbon cable (ros window may be dirty)
7/8/2017 12:53:45 PM • Xerox Phaser... • Answered on Jul 08, 2017
2answers
Hello, I have a Xerox Phaser 7760 and I got a Cyan ATC Sensor Failure Code 009-382 and the printer does not let me print anything. can you please help me with this issue?
If you wish to get some details about printer repair ; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
5/26/2016 7:39:21 PM • Xerox Phaser... • Answered on May 26, 2016
4answers
Xerox Phaser 7760 prints white diagonal lines
Are the white lines in one color or all colors? If it is just one color you should try cleaning the laser window. Open the front cover and in the cover there should be a cleaning wand. Remove the waste cartridge and use the cleaning wand to clean the laser windows located behind the waste cartridge.
11/25/2015 7:05:00 PM • Xerox Phaser... • Answered on Nov 25, 2015
Xerox Phaser 7760 Prints White Lines Diagonally Across Page
That is normally caused by a bad developer housing.
11/25/2015 7:01:09 PM • Xerox Phaser... • Answered on Nov 25, 2015
Why phaser 7760 toner cartridge not recognized
You will need to contact your local Xerox concessionaire for further information. It can be a faulty CRUM chip on the side of the toner cartridge (very un-likely) or if your machine is quite new then I've seen an NVM location needed to be updated. (slim possibility) Xerox Concessionaire is the best course of action. Good Luck.
7/3/2015 11:29:45 PM • Xerox Phaser... • Answered on Jul 03, 2015
Phaser 7760 firmware stuck
I expect you have this one sorted by now. However if not I would advise you to contact Xerox asap and hope you have a contract. Good Luck.
6/2/2015 9:12:17 PM • Xerox Phaser... • Answered on Jun 02, 2015
Hola tengo una xerox 7760, el problema que tengo es que trama el color magenta, hace una líneas más claras horizontales. Gracias
Pruebe a utilizer ingl?s. Obtendr? una major respuesta.
3/30/2015 11:46:48 PM • Xerox Phaser... • Answered on Mar 30, 2015
Accumulator belt for Xerox Phaser 7760: can I refurbish this unit myself? If so where can I buy the parts to refurb the belt?
064K91451 iteminconline they sell the belt only and also the home position sensor encase you have an error.
9/12/2014 1:05:50 AM • Xerox Phaser... • Answered on Sep 12, 2014
Print Directly to 7760DN from iPad 3 iOS 5.1 ?
Hey I have a xerox wc7328 connected to my andriod. There is a app that is called "printback" from xerox. Follow the instructions in the website where you download the app and its easy. Good luck don't forget to visit us at iteminconline we have all your xerox parts that you need. New and refurb.
9/12/2014 12:55:38 AM • Xerox Phaser... • Answered on Sep 12, 2014
3answers
004-363
Black Imaging Unit Motor Failure.
8/27/2014 8:22:26 AM • Xerox Phaser... • Answered on Aug 27, 2014
Fault 004-350 occurs right after booting up
Faulty ROS or ribbon cable, (ros window may be dirty)
3/23/2014 6:27:29 PM • Xerox Phaser... • Answered on Mar 23, 2014
Xerox phaser 7760 close door a in the display
This is a very common problem with the 77X0 series. The lower left door magnets have come loose and won't hold the door closed all the way. If you press on the door and hold it closed...the error should go away. The "Door A" needs replaced unless you can get just the magnets and replace them.
3/16/2014 2:27:44 AM • Xerox Phaser... • Answered on Mar 16, 2014
Find a lift assebly
006K23012 is the part number but no price sorry
12/8/2013 12:52:06 AM • Xerox Phaser... • Answered on Dec 08, 2013
Xerox Phaser 7760/YDX Laser Printer Logo
107 questions posted
Top Xerox Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
View Most Popular
Phaser Xerox
  • Phaser Xerox
Most Popular Question
hola tengo una xerox 7760 el problema
  • Office Equipment & Supplies
