Maytag Neptune MAH7500WH Front Load Washer Logo
Joanne Kenny Posted on Mar 27, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Maytag Neptune stops during rinse cycles
Each time my washing machine fills for a rinse cycle, it shuts itself off without spinning or draining. I have to monitor the machine and hit "start" 3 (additional) times to complete the loads. 1 service rep thinks it's the water valve (lots of $$ to replace). Any other ideas?
  • 2 more comments
  • Anonymous Jan 13, 2008
    We have the same problem. When the hit hits the rinse cycle it stops and the door can be opened. Inside it appears that the water level is correct. It does this with the rinse cycle on cold. It appears that with the cycle on warm it sometimes stops and sometimes continues.
    Pressing the start button starts the washing machine up with no problems till it hits the next rinse cycle.
    I have not tried cleaning the screens yet...will post if that solution works though as stated earlier it does appear that the water gets in- maybe not enough?
  • Bob Enders Jun 29, 2008
    maytag neptune model mah7500aww stops on spin cycle
  • Anonymous Mar 15, 2014
    The washing machine is repeatedly pausing in between the starts and stops during the wash and rinse cycles...
  • Anonymous Mar 23, 2014
    Will fill but won't cycle to spin or rinse
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Sep 14, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2528
Points
Could yoy please explain what the "screen" is?
Thanks,
Carl.
Anonymous
Level 1:
  • Contributor 4 Answers
  • Posted on Jan 18, 2008
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
3595
Points
7
Cleaning the screen seems to have worked. I used compressed air at about 100 psi to do the job.
Thank you to "GUEST" !!
A
Anonymous
I think the cold side of your water valve is stopped up at the screen. Just take your hose off at the machine and get the crud off the screen in the valve. It only does it in rinse because you have cold rinses. When warm water comes in, it will fill just fine because the hot water is not blocked
  • Anonymous Dec 22, 2011
    Cleaning the screens worked for me, too. The water hoses have two screens. One at the faucet side, and one at the washer side. The washer side of my hose was pretty gunked up. I used a spray bottle with water to rinse it clean, and the washer works fine again.
Anonymous
Level 1:
Welcome Back:
Visited the website for 2 consecutive days.
  • Posted on May 07, 2007
Anonymous
Contributor
Level 1:
Welcome Back:
Answers
Questions
0
Helped
2528
Points
How would you know if it fills to the correct level sine you can't see inside?
douglas smith
Level 3:
President:
  • Master 1,462 Answers
  • Posted on Mar 28, 2007
douglas smith
Master
Level 3:
President:
Answers
1462
Questions
0
Helped
898757
Points
3964
From what you say it doesnt sound like a water valve. does it fill to correct level the first time round?
Wash cycle are running to long
FIXED Maytag Neptune, Timer Problem - ApplianceBlog
www.applianceblog.com/.../23387-Maytag-Neptune-Timer-Problem
Mar 4, 2011 - 8 posts - ‎3 authors
My countdown timer is stuck at the 33-minute level in the "wash cycle", and repeatedlyruns for a 30-40 seconds, then stops, then runs, then ... Maytag Neptune TL Washing Machine stops in spin cycle ...
Jul 25, 2013
Maytag Neptune Washer Won't Spin/drain
Jul 4, 2013
Neptune TL Washer FAV6800AWW - DC and UC ...
Jul 3, 2007
MAYTAG NEPTUNE WASHER CONTROL PANEL ...
Jun 29, 2005
More results from www.applianceblog.com
Troubleshooting a Too-Long Wash Cycle - whirlpool washingmachine ...
ask.metafilter.com/233920/Troubleshooting-a-TooLong-Wash-Cycle
Jan 25, 2013 - We have a Whirlpool Duet washing machine (about 2 years old). Thecycle is taking WAY too long to complete. The load that's running now ...
Maytag Neptune washer repair: motor/motor control circuit ...
? 12:10
https://www.youtube.com/watch?v=ITTbDh8CFEU
Dec 11, 2013 - Uploaded by daytonaturbofreak
Maytag Neptune washer motor/motor control circuit board ... my board just fried - is your washer still working? wondering how longthe conversion fix will last. ... Other times it will run a completecycle without any malfunctions.
Model MAH 7800 drain pump will not run, door locks, tub spins, water drains by gravity
Well your drain pump needs attention for sure. There could be an object lodged against propellers or it may need to be relaced. Try unplugging the connector that goes to the pump and plugging back in. Also try tapping the the motor part of the drain assembly while in spin cycle before replacing. Good luck.
Model fav6800aww drains during the wash and rinse cycle but does not drain during the spin cycle. it give an dc code during the spin cycle which i know that means unbalance but what does that have to do...
Clutch issue and possible time for a tub seal replacement
Google this for a post that covers the Clutch removal and inspection/repair;
""Neptune TL Washer FAV6800AWW"" you will find the Service Manual in post 5 of that sticky.
Google this for Outer Tub bearing rebuild;""
FAV6800A/FAV9800A Outer Tub bearing replacement""
Hello I have a Maytag Washer Model A512 The machine goes through a regular cycle OK - However, it DOES drains the water out during the rinse cycle, but does NOT drain the water out during the spin...
The timer will always advance to the next program if the machine does not fully drain. There is ALWAYS a spin when draining the water out, there is only one pump and one motor. The waterlogged laundry maybe telling the timer that there is still water in the tub. Put the machine on "Spin" and cheat the lid switch into thinking that the lid is closed. Use a clothes peg or wide ended screwdriver and see if there really is a spin....
The wash time continues to increase on every cycle. I have a Maytag Neptune TL Washer.
Thank you my machine model number. The reason I ask is so many folks post non FAV6800A/FAV9800A issues in this forum. This forum doesn’t ask for machine model number and serial number. Here we go.
Does your machine seem to take longer than normal to fill with water?
Does the machine increase the time during the Spin Cycle of the Wash Cycle?
Are there any error codes to the LED display such as dC or uC?
Do you want to work toward a DIY fix? If not maybe we can get a solid feel for the issue that will help you in the decision process to bring in a repair company or replace.
So I can better understand the issue can you start a Quick Wash cycle with Soil and Spin settings set to lowest setting and if you could place a couple of bath towels in the wash basket for a load.
I want to see if the machine will go thru the Wash, Rinse and Spin cycle within the 27 to 29 min time of a Quick Wash cycle. I want to see if the machine is increasing Washer Cycle time in the Spin Cycle of the Wash Cycle.
You should enter the Rinse Cycle at the 20 min mark on the LED display.
You should enter the Spin Cycle at the 10 min mark on the LED display.
Watch the cycle and see if you have similar times as I do. Let me know if the washer has any off balance issues as it enters into the Spin Cycle…..Rich
2answers
Maytage MAH6500AWW Overloaded washer now leaks when filling
since you can drain it
take off the back and watch what happens when u turn it on
i believe you make have a loose drain connection
3helpful
MAYTAG NEPTUNE MAH9700AWW continues to fill on rinse, code "oe",
if the water continues to fill even with power off, and you have to manually shut in off at the wall valve, the 3-way inlet valve is stuck open. you have to replace it. $90
Maytag neptune stops in mid cycle
It sounds like your drain pump is going. Neptunes are suppose to neqarly dry the clothes with how fast it spins. A poor drain pump/motor, could cause this to be less effective. There could also be something in the drain lines. I would check that before you pay money on a pump though.
2answers
Cold water will not stop filling during rinse
while the unit is filling in the warm cycle. reach behind and shut off the hot water tap.I bet the water flow stops filling, if so, you would need to change the inlet valve on the machine. You see, in warm, if the cold is not filling, you still hear the hot filling and the unit will advance. The rinse cycles are mostly "cold" only. if the valve is not opening it will not allow it to advance from the rinse section on the board.
2answers
Shuts itself off before each Rinse or spin cycle.
Maybe your spin or rinse cycle button is in the off mode. Refer to your user's manual, if you hv one.
Top Maytag Washing Machines Experts
ZJ Limited
ZJ Limited
john h
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
