That watch might take two batteries when it's open there should be a big battery which is a lithium but under it will be a silver oxide batter that needs to be replaced if there is not then the analog has to be lubricated and spun out the worst case senerial is u will have to replace the movement remember all was change ur batteries asap when the go dead. Digital batteries always last longer than the analog batts do
yes,you take the rubber backing off the watch...on the back you'll see 4 screws...you'll need a jewelers screwdriver to get them out....you'll see a large batter on top and UNDERNEATH it is a SMALL batter...one is for the digital and the other for the hands.....
That's right- your watch needs battery replacement. No matter you wear it every day or just once a year - battery life comes to an end in a two years time approximately. Expect the same all over and over again.
Rate me, plz.
It's too expensive to change it on proper service or mall... you can purchase battery for amazon and change it at home, take a look here: Rayovac Batteries Lasts as Long Costs Less. I hope this helped. Cheers
you might wanna check the solenode to the starter on the front fender if there is not one on the starter you may have a bad starter you shouldve check the starter to see if it worked when you put the jumpers to it thats what i would do
Boost your car with jumper cables and let the car idle or drive around for about 20 minutes for the alternather charge the batter on its own .if the car shuts off after you started it might be your alternather is no good . the reason why ur alternather might not be working is because the batter all it does is give enough power for the starter to crank the engine as soon as the engine starts running it gets all its juice from the alternather and it charges the batter as well. but some times when the alternather works and the batter is dead meaning all the cells inside the batter are dead it will never take the charge from the alternather. so you would have to change the batter.
if you would like to know how you can you test both parts useing a volt-a-meter... just ask...
p.s. I think its ur batter if you never changed it. so get that changed for the winter so you wont have any more starting problems during cold wheaters
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US) These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
Press ADJUST to set SECONDS to zero.
Press START/STOP to select MINUTES.
Press ADJUST to change.
Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
Press MODE when done.
To display DATE from Time display , press START/STOP.
With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
Press ADJUST to change.. Press MODE when done.
Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
With time displayed, press MODE to select Chrono Mode.
Press START/STOP to start.
Press ADJUST to view lap time. Press again to sesume lap timing.
Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
