20 Most Recent Timex 5B841 Wristwatch Questions & Answers
how i get differnent light in lasika watch
Timex 5B841... | Answered on May 29, 2019
Press and hold the start/split button. The time zone will blink. Press start/split again to choose the your desired zone
Timex 5B841... | Answered on Dec 07, 2013
These are settings for the Timex SPORTS 1440 Magnetism (5b841 -W163US)
These are for the 4 button SPORTS 1440 (not 6 button) - they will also work for the 1440 SPORTS "Informer" model wrist watch - you will NOT find these instructions on the Timex website - only the 6 button which will not work on these watches is on that site!
TIME AND DATE
  1. Press and hold MODE until HOURS digits flash (you'll be in Alarm Mode) Press MODE again to enter TIME mode, SECONDS digits will flash.
  2. Press ADJUST to set SECONDS to zero.
  3. Press START/STOP to select MINUTES.
  4. Press ADJUST to change.
  5. Repeat to set HOURS, MONTH, DAYS, and DAY of WEEK. Go through 12 hours to set AM or PM.
  6. Press MODE when done.
  7. To display DATE from Time display , press START/STOP.
  8. With DATE displayed press and hold START/STOP, then press ADJUST to change display between DATE-MONTH and MONTH-DATE.
  9. With TIME displayed, press and hold ADJUST, then press MODE to switch between 12-and 24-hour format.
ALARM AND HOURLY CHIME
  1. Press and hold MODE until HOURS digits, DAY, and A or P (for AM or PM) flash.
  2. Press ADJUST to change HOURS digits. Go through 12 hours for AM or PM.
  4. Press ADJUST to change.. Press MODE when done.
  5. Press and hold ADJUST, then press START/STOP to turn chime on/off. Press START/STOP again to turn alarm on /off. Release START/STOP when done.
CHRONOGRAPH
  1. Chronograph will count up to 24 hours. Lap times are not stored. After 40 minutes chrono display changes from seconds to minutes.
  2. With time displayed, press MODE to select Chrono Mode.
  3. Press START/STOP to start.
  4. Press ADJUST to view lap time. Press again to sesume lap timing.
  5. Press START/STOP to stop timing . Press ADJUST to reset chrono to zero.
  6. Repeat for successive laps.
Have fun! - Not a bad watch for the money! - - Silver Bullet
Timex 5B841... | Answered on Jul 16, 2013
Hi Krystal,
Timex has two ways to find information about your particular watch. Some of these models only have a guide consisting of a few pages. If your watch is the 1440 series, the following info may help you. If you don't have the manual, Try this link:
If your watch is the W-207 movement use this guide:
http://assets.timex.com/user_guides/W207_M115/W207_M115_NA_EN.pdf
Complete Timex link site:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Now, look up the model number, or if you cannot find that, check the three-digit Module Number from the back of the watch. Click on it in the Module Table, and download a PDF of your watch setting-instructions/manual.
If you need more specialized help, call Timex in Little Rock, Arkansas at 1-800-448-4639.
I hope this helps you. Thanks, Bill
Timex 5B841... | Answered on Sep 08, 2010
mcdevito75 here, You need the MODE and SET buttons right now, Press Mode, you may have to hold down the mode button 2-3 seconds, now see display flashing, now press the set button for each funtion you want, hour, minute etc. after each function is set press mode to move to the next function, when all functions are set presss mode again to seee steady display. If needed here is Timex customer service, 800-448-4639 Hope this helps.
Timex 5B841... | Answered on Aug 11, 2010
mcdevito75 here, The mode button should be pressed, note dial blinking, now press set and that particular setting will cahnge, now adjust for the correct time.
Timex 5B841... | Answered on Jun 29, 2010
You have to adjust the date every February (28 or 29 days), April, June, September and November (each 30 days). Self adjusting calendars are called Perpetual Calendars and this feature is quite expensive, especially in mechanical watches. Your watch has calendar ring with 31 days printed on and the simple calendar mechanism which is changing dates from 1 to 31 inclusive,day after day, so, when the 30-day month is ending and there is no 31st date to follow, your calendar is showing 31st anyway,instead of 1st of the next month. This is when you have to adjust date. Now about the date adjusting. If you pull out crown gently, you will notice there are two clicks (positions), not just one. So the first click, when crown is not pulled out fully, is exactly for day/date adjustment. If you pull the crown further out, watch is in hand adjustment mode. Try it carefully and you will find out the right position.
Rate me, please.
Timex 5B841... | Answered on Jan 12, 2010
you can find a exper in the watch shop<a href="http://warhammeronline.cheap-wow-accounts.com/" >cheap warhammer gold</a> <a href="http://www.mmostudio.com/" >warhammer online gold</a>
Timex 5B841... | Answered on Dec 25, 2009
http://www.timex.com/gp/node/n/255235011/178-1795200-7359408?ie=UTF8&timexBrand=core
This link will take you to the official Timex page where you can download the instruction manuals for any of their watches.
Timex 5B841... | Answered on Jan 05, 2009
Since I'm not sure which Timex you have here's the easiest thing I can do for you:
timex.com should be able to send a PDF of your manuel
Timex 5B841... | Answered on Jul 15, 2008
Timex 5B841 Wristwatch Logo
22 questions posted
Top Timex Watches Experts
freddyfox
Jerry Greenberg
Jerry Greenberg
Dustin
Dustin
Are you a Timex Watch Expert? Answer questions, earn points and help others
View Most Popular
Timex Watches
  • Timex Watches
Most Popular Question
adjust date classic watch
  • Watches
