Need a source to buy replacement speaker cables/wires and connectors for Sony dav-hdx576wf home theater system.
Since noone else gave you a good answer I will. I lost some cables to mine a while ago and found this awesome jerry rig solution; Go to radio shack, and ask for '14-16 gauge star ring terminal connectors' Should come in a pack of 10 and be about 2$. On the back of the unit where these connectors fit, there should be two prongs. You will need two star-rings for each connector slot. Wire up your connectors and crimp the ends LIGHTLY with a pair of pliers. The star-ring connector connected to the negative wire should be inserted to the left prong, (left if you are facing the back of the unit), and the right prong is the positive. If you did everything correctly, you should be able to make your own wires for sony stereo systems whenever you need to. Saved my ***, hope it did the same for you. Here is a link to what they look like. http://www.shopping.com/radio-shack-non-insulated-crimp-on-star-ring-terminals-10-pack/info
SOURCE: Sony speaker connectors
Try this guy on eBay who is selling 2 varieties of Sony connectors, plus a ton of others
http://stores.ebay.com/BOGUE-ENGINEERING-GROUP
I'm about to pull the trigger on a set of his 4.2mm connectors for Sony HCD-HDX500 for $26
SOURCE: No sound from TV thru sony bravia hdx576wf; DVD & CD audio ok.
Could be a sync calibration issue. Try to divert the TV sound to another input source on the Hometheatre system if possible, if it is a go then maybe the TV audio needs to be recalibrated. Make sure TV audio setup menu option has not changed also.
SOURCE: I need power and volume control codes only for my
Not sure if you have tried the 3 codes listed in the OCAP 4 universal remote manual for Sony Receivers
31759, 30158, 31758
Sony DVD players
20533, 21533, 20864, 21033, 21070, 21431, 21536
In addition I find a way of finding the codes at the Universal Remote support site
http://www.urcsupport.com/html.php?page_id=313
But it gives a generic code for Sony DVD systems
20533
Not sure if you have already tried all this. The other option might be to find if the Sony system remote has the code for the Charter cable modem.
