Nikon D60 Digital Camera Logo
Gene R. Halford Posted on Aug 05, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
In the P S A M modes my shots have a moderate blue cast. This just started without reason. The manuakl was no help because it didn't even list the problem.
Level 3:
One Above All:
The expert with highest point at the last day of the past 12 weeks.
Top Expert:
  • Nikon Master 102,366 Answers
  • Posted on Aug 05, 2012
Nikon Master
Level 3:
One Above All:
Top Expert:
Answers
102366
Questions
0
Helped
10444161
Points
622693
Check your white balance setting. In the point&shoot modes the camera sets the white balance automatically. In the PSAM modes you get to choose the white balance. Set it to Auto and see if that makes any difference. Set it to Cloudy or Shade and see if the pictures come out reddish or yellowish.
My Coleman Xtreme won't charge. Help!
Hello, my camera is doing the same thing, did you ever find out what the problem is and how to bypass this
When i turn on my computer and it goes to the home screen after about a min this blue screen comes up saying its crashing and then a black sceen comes up with option of using safe mode is there a fix or is...
John,
The blue screen you are seeing is the Blue Screen of Death. This can be caused by many things going wrong with windows and/or hardware. First things to rule out are recently installed drivers/software. If you installed anything like drivers for a new camera, a new application or even a new thumb drive then you will want to select Safe Mode at that screen and uninstall whatever you installed if you can login with safe mode.
If you didn't install anything new then the issue is much harder to track down. If this just started happening out of the blue,haha pun untended, then it could be anything from a bad hard drive, bad RAM, to Windows having an issues. The best place to start is to see if your computer goes into safe mode. If you can get into safe mode it doesn't rule out a HD issue but makes it easier to recover from if it is and proves that windows core files aren't affected. The reason a bad HD could cause this is there are very small sections on your HD called sectors that store data. Often times these sectors go bad and the HD can't read or write to them. If there are needed files for windows on those sectors you get the blue screen you are seeing. So if you can get into safe mode backup your data just in case this is a bad drive. The drives tend to snowball from being just annoying to dead if you have issues with bad sectors. So I would backup things now if you can. Another thing to check for is if the hard drive makes a mechanical click just before the blue screen. If that is the case then it is definitely the hard drive. Backup your data as fast as you can because that drive has a very short life span left. That noise is also known as the click of death.
If you don't hear the click before the blue screen and you can get into safe mode, I would next check to see if RAM is causing the issue. I have seen bad sticks of RAM, memory, go bad in a way where it can't be written to/read from but is seen by the computer. When windows goes to write to a memory location and it can't then windows crashes giving the blue screen you see. This is somewhat easy to test if you multiple sticks of memory. Power down your computer and unplug it. Then open your computer and you will see two long sticks of RAM. You can google search for SD or DDR RAM to see pictures of what it looks like. Remove one of the sticks then plug in your computer and power it up. See if you still get the blue screen. If so then do the same with the other stick of RAM. If it works then the cause was that stick of RAM.
If that doesn't fix it then I would suggest doing a full backup of the system in safe mode and running the restore that came with the computer. This restore will delete everything from your computer if you select that option so remember to backup your data. This could just be an issue where something within windows became corrupt. Along with data being removed with a recovery, all of the software you installed since you got the computer will be removed as well as applications settings. If you have applications that you lost the product key/license key for there are applications like Magic Jellybean which can recover those if needed.
Generally the blue screen of death isn't the end of the computer, especially for a desktop. The hardware is normally cheap enough to be replaced without being near the price of new computer. Also if this computer is still under warranty the manufacturer will send the hardware for free if it is a hardware issue. Another option if the above steps don't help is to bring it to a local computer repair shop. Generally they have a diagnostic fee that counts towards the repair if you get it fixed. The good thing about the repair shops is they have the extra hardware around to swap things out until they figure out what is causing it.
My 1998 grand cherokee makes a very loud noise from the muffler, it sounds like a gun shot, shakes and then stops
Didn't you go for a road test with the mechanic along
Why didn't the repair shop resolve?
1helpful
When I take a picture in p setting it comes out with a blue cast. When taken i automatic, it comes out in correct colors
You didn't specify the model of your camera so I can't be too precise here.
Since it does appear to be a white balance issue, I'd say you've got the white balance set too warm. The camera compensates by adding blue to the scene and hence you get the blue tint. Either set the white balance to match the scene, or else set it to "Auto".
Hello, i have problem with my Iphone 3g 8gb. The problem is that, that after a few opening it stoped to work. It was not first time when i was opening it because wanted to make camera working well, but...
I would strongly suggest to bring it to the nearest apple store, but try these combinations as well.
1. Make sure your iPhone is connected to its charger for about 20 minutes, see if there's any reaction. The battery may be causing the problem.
2. If that's not the case, keep the phone connected to the charger, press the power button for 10 seconds, then press the home button without letting go of the power button for another 10 seconds.
3. Release the power button, and it should automatically start in DFU mode.
If this does not work, repeat all the steps above now with your USB connected to the laptop, and try restoring it with iTunes.
Unable to start laptop
I understand the urgency and also the importance of data stored in the laptop.
As the laptop is unable to start in normal mode let us try in safe mode.
Follow the steps below:
1. Turn the laptop off completely.
2. Press the power on button to turn it on and at the same time simultaneously keep tapping ' F8 ' key on key pad until you see a advanced boot options screen.
3. Select 'safe mode' and hit enter.
Thank you.
Powershot A75 with pink/blue streaks
I have similar problem.highlights overexposed,with streaks of pixels running vertically.overall pinkish hue
2answers
Blue photos
You probably needed to reset the manual white balance. Lighting conditions can change considerably in 10 minutes at sunrise and sunset.
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
