Light flashes 7 times when key is turned on
Yup you got a code seven failure code, speed pot malfunction . What
pots typically do is that they oxidise. This pot is a variable
rersistor that opeates between 0 - 30k ohms. When tuning the pot it
shoud ram up and down smoothly. To test for this
You may also need a VOM meter only $9
http://www.amazon.com/Mastech-YG188-Pocket-size-analog-multimeter/dp/B00064CH6A/ref=sr_1_8?s=hi&ie=UTF8&qid=1339024102&sr=1-8
Disconnect
batteries from the scooter. Simply attach the multimeter to the pots
terminals, select correct ohms scale and watch the needle. Th needle
when turning the pot should move gracefully up to 30k down to zero as
the pot dial scooter speed increases. Failure is detected when the
needle jumps around, the oxidation causes the pot to connect
inteermitently. USE CRC CONTACT Cleaner to get the oxidation out of the
pot. The potss are not sealed so there are little holes you can spray
into. Use liberal of cleanner.
SOURCE: Celebrity Pride SC440 scooter makes continuous clicking sound
the motor break assembly is going bad, if not replaced soon it will quickly draw down your batteries. [email protected]
SOURCE: The lights indicate there is
Hi can you tell me the flash code ? how many imes it flashes before there is a pause etc.
to help you with this check the manual
http://www.pridemobility.co.uk/docs/UK_Celebrity_X_om.pdf
goto page 35.
Regads
Gewiz.
SOURCE: Pride celebrity x 3-Wheel scooter My scooter is
Hi
Trade it in for an 8kph Speed, as i am assuming that yours is only a 4 kph Speed,
Gerry.
SOURCE: pride celebrity 4 wheel wont turn on
Hi
Please Check that your Freewheel Lever is Fully in Position as if is Slightly out of Position it will Not Work,
Gerry.
SOURCE: Lost key to Pride Celebrity
DJ should work try it if all else fails call Pride @ 1-800-800-8586 ask for tech Support and ask to get a set of keys or You can replace the keyed switch with a on/off toggle switch Hope this helps
