Fuji Finepix Z20fd Digital Camera Logo
Anonymous Posted on Jul 22, 2012
How do I change the shutter speed on the Fuji Film Fiinepix Z20 fd
Hi, im going on holiday in 2 days and my camera works fine but i want to be able to capture pictures as soon as i press the shutter button but it has a horrible delay and i havent changed the setting's, i dont even know how to change the settings lol! the delay after i press it is about 4.7 seconds after, but i need to capture instantly or a second after, i hate the delay! HELP!!!!!!!
  • Anonymous Jul 22, 2012
    will that make the picture take it straight away and not have so much of a delay?:D
    HELP! IT DOESNT WORK!
Anonymous
Level 2:
Guru:
  • Expert 166 Answers
  • Posted on Jul 22, 2012
Anonymous
Expert
Level 2:
Guru:
Answers
166
Questions
0
Helped
59240
Points
520
Instructions
Turn on the camera and rotate the shooting dial to one of the shooting modes, such as auto.
Press the "F-Mode" button to adjust frequent settings like ISO and picture quality.
Use the up and down arrow buttons to navigate between settings. Press the right arrow button to present the available options.
Use the up and down arrows again to adjust the settings option. Press the "Menu/OK" button to apply the change.
Exit the menu by pressing the F-Mode button again. Press the Menu/OK button while in shooting mode to adjust less frequent options, such as white balance and the auto-focus mode.
Use the up and down arrow buttons to navigate between settings, similar to the F-Mode menu. Press the right arrow button to present the available options.
2 Related Answers
Anonymous
  • 11967 Answers
  • Posted on Dec 31, 2009
SOURCE: shutter speed on the auto mode of my s1000 camera
You need to press the shutter button half-way and allow the camera to lock in the focus before you press the rest of the way. This eliminates "shutter lag".
Anonymous
  • 11967 Answers
  • Posted on Jan 03, 2010
SOURCE: I often miss a shot because there seems to be a
It's called "shutter lag"...a common problem with all point and shoot cameras. To avoid it, press the shutter button half-way and allow the camera to lock in the focus (it will beep) before pressing the rest of the way.
My polaroid pictures are coming out blank?
I assume they are coming out almost completely white. Here are some guesses based on my experience with 4x5 Polaroid film from decades ago. Things may have changed.
First guess: This type of film has small packets of chemicals that are popped open and spread by rollers in the camera. These chemicals develop the film. If the pinch roller's no longer squeeze tightly enough, the film will come out white. Try googling your camera name and rollers to see if others have this problem.
Second guess: Another possibility is the film was not stored properly or expired. Have you tried replacing the film?
Third guess: Not likely, because I expect this camera is fully automatic, but are you able to adjust shutter speed or aperture? The images may be over exposed if shutter speed is slow. Are there mode settings like A, T and M? If so, put the camera into A mode. When you press the button do you hear a fast and immediate click-click, or do you hear a click followed by another click shortly after?
How do i change the shutter speed on fuji s2 pro
In the P, S, and M modes, turn the command dial on the back of the camera. In the P and S modes the aperture will also change to compensate. In the A mode, turn the secondary command dial on the front to change the aperture, and the shutter speed will change to compensate.
The shutter speeds on my Horizon Perfekt do not change when i adjust the dial.
The shutter speed is controlled by the width of the slit exposing the film. So, the lens will swing at the same speed when set at 1/500 or 1/60 (White setting), therefore it appears on the outside that the shutter speed has not changed. The swing has only 2 speeds, White fast, Yellow slow, selected by the switch on the left beside the rewind knob.
To confirm that the width of the slit is changing (actual shutter speed), open the back and fire the shutter on Yellow 2 (half second), you will see the slit is fully open as the lens swings. Next try Yellow 8, you will see the slit is less than half open, so it exposes the film for a shorter time by having a narrower slit , not faster swing.
This is the same principle in many cameras with curtain shutter.
I hope this answers your question.
I have s5500 fuji film please tell me whats sitting speed and oprercher with a vrey hot day full sunshine
It's impossible to tell you what shutter and aperture settings would be best without actually being there. Why don't you just rely on the built-in meter? On a bright sunny day, you could set the ISO to its lowest setting and let the camera figure out the correct exposure.
Ihave a fine pix z20. The LCD screen is not working. The camera still takes pictures fine and the card prints the pics fine but the screen is just white with a grey line through it. I forgot to register...
If you still have few days warranty, call Fuji at 1-800-800-3854 , select option 1 and register your product, or check the website. They will tell you if the camera is still on warranty.
Here also US website.
Fujifilm: Support & Contact Center
If you leave outside US see fuji website for contact:
Home | Fujifilm Global
FUJIFILM Australia
FUJIFILM Europe
2helpful
My Fuji digital camera model Finepix Z20 is showing a protected card message when I insert both my old SD card and my new SD card. My old SD card was working fine yesterday but now it says protected c
Good day,
This is a common problem that many people experience with their SD Cards.
It is normally an easy fix and you can follow a method that I posted on my tips here:
http://www.fixya.com/support/r7042428-sd_card_write_protect
Please feel free to let me know if this was helpful!
Regards
Shutter lag on fuji finepix s7000 - is there a solution ?
2 things - you could do 1 or both, depending on the photographic situation:
1) If you can choose manual focusing, select manual focussing & prefocus on subject. This eliminates the need to refocus. I do this lots with the S9500 model.
2) If you can shoot in manual mode, use auto exposure to see what shutter speed & aperture the camera selects when the camera is pointed at the ground (or other suitably lit spot). Change to manual exposure & set the aperture & shutter speed indicated by the camera in AUTO mode.
Once you do either or both of these you will get instantaneous shutter release.
Practise on unimportant subjects first and see how you go.
2answers
FEE MESSAGE
Yes, on this camera you leave the aperture ring at f22 and use the camera's controls to set your f-stop. It won't work is you change the ring on the lens. You gain the control of the aperture in the 'M' and 'A' modes. The 'P' setting is for the camera to pick both speed and aperture for you. 'S' is shutter priority, etc
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
