20 Most Recent Fuji FinePix S2 Pro Digital Camera Questions & Answers
Location of serial number
this was found at fuji
  • Q.Where can I find the serial number of the digital camera?
  • A.The serial number is printed on the label attached to the bottom of the digital camera.
Where can find the serial number of the digital camera
5/6/2016 2:09:10 AM • Fuji FinePix S2... • Answered on May 06, 2016
2answers
Fuji Finepix S2 Pro
Ensure the batteries are the correct kind and chemical makeup (yes it does make a difference!)
try using lithium or alkaline as oppose to standard =]
Otherwise there may be an issue with the camera itself, check for warranty? if it isnt under warranty, document the error message/number, consult the manual AND the support site for the manufacturer.
good luck! =]
5/6/2016 1:03:30 AM • Fuji FinePix S2... • Answered on May 06, 2016
0answers
Fuji x20
Be the first to answer 12/15/2013 4:10:12 PM • Fuji FinePix S2... • Posted on Dec 15, 2013Be the first to answer
Error signal
You should have two types of batteries. 2 CR123A batteries: (lithium) 4 AA batteries (alkaline or nickel-metal hydride) Never use Nicad batteries. Never use different batteries together. that is for the four AA batteries. They should be the same brand and the same capacity.The lithium batteries should be the same brand and same date.Before changing batteries, always switch off the camera. When you use rechargeable batteries, be sure you did charge them fully, before putting them in the camera.
10/28/2013 11:19:26 PM • Fuji FinePix S2... • Answered on Oct 28, 2013
Error batteries are fully recharged
What is the error?
10/28/2013 2:46:01 PM • Fuji FinePix S2... • Answered on Oct 28, 2013
My finepix s2 can take a picture, but can see
check your memory card for errors
10/22/2013 6:51:56 PM • Fuji FinePix S2... • Answered on Oct 22, 2013
0answers
Hi there. A mystery error shows the Display of my Finepix S2 pro. Its like that: "o - -" or "o _ _" in the upper Display. Has anyone an idea for that? Best regards, Harry
Try resetting the camera by removing the battery for 15 mins. Replace the battery then go to the camera's Menu and scroll through the settings to set the Date and Time.
4/18/2013 1:25:17 PM • Fuji FinePix S2... • Answered on Apr 18, 2013
How do i change the shutter speed on fuji s2 pro
In the P, S, and M modes, turn the command dial on the back of the camera. In the P and S modes the aperture will also change to compensate. In the A mode, turn the secondary command dial on the front to change the aperture, and the shutter speed will change to compensate.
10/29/2012 3:18:01 PM • Fuji FinePix S2... • Answered on Oct 29, 2012
No image shows when I take picture
Usually the photo is displayed for a short period of time. Try the setup in the menu. There should be an option for previewing recent pictures.
6/20/2012 7:51:50 PM • Fuji FinePix S2... • Answered on Jun 20, 2012
2answers
Hi. I have an s2
I believe the max size memory card the S2 Pro will accept is 2MB.
3/31/2012 3:45:49 AM • Fuji FinePix S2... • Answered on Mar 31, 2012
3answers
I bought a 4 gig CF card for my fuji S2, and when
From administrative tools in the control panel on a pc,you can format a 4 gig card to fat (not fat32) in the disk management window. It works fine in my Fuji s2.
3/31/2012 3:43:22 AM • Fuji FinePix S2... • Answered on Mar 31, 2012
Fuji FinePix S2 Pro Digital Camera Logo
107 questions posted
Top Fuji Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Fuji Camera Expert? Answer questions, earn points and help others
View Most Popular
FinePix Fuji
  • FinePix Fuji
Most Popular Question
error message card not initialized
  • Cameras
