20 Most Recent Nikon N65 35mm SLR Camera Questions & Answers
then I would find out how to return it to place of purchase as defective .
Nikon N65 35mm... | Answered on Mar 25, 2016
Hello Anonymous,
With each shot this camera auto advances the film. Maybe, when the film door is closed the film is not seated properly all to the right side. Thus the take up reel is not pulling the film.
Being as the N65 appeared in 2000, it is possible it may be stoved-up. Also, if so these are not worth fixing. For the cost of fixing I would look for a N80; a very nice camera much improved over the N65.
Cordially,
Nikon N65 35mm... | Answered on Feb 24, 2015
was the film set into the camera correctly ?
Nikon N65 35mm... | Answered on Feb 18, 2015
are the lenses clean so the camera can focus?
Nikon N65 35mm... | Answered on Feb 13, 2015
The Nikon N65 has a built-in film advance (power winder) so all you need to do is take a photo and it should advance. If no, the film isn't loaded properly or the drive is broken.
Nikon N65 35mm... | Answered on Jan 06, 2015
Hi Jennifer,
Not too sure what that is, but first thing I would check is that you lens is set to its smallest aperture, such as f/22. Many times that err message means the lens is not closed down all the way. After closing the lens down the camera dials will set the aperture. Also, on many Nikon D type lens, not the G type, there is a small push pull button to lock the lens as it smallest opening.
Cordially,
Nikon N65 35mm... | Answered on May 26, 2014
The most likely culprit is a broken mount on the lens. Some Nikkor lenses have a plastic mount whose bayonet blades can break off when the camera is subjected to a shock. Since you neglected to specify the lens I don't know if this is the case with yours.
If you have access to another lens, try it. If that one stays on then the problem is with your lens. If that one doesn't stay on then the problem is most likely the mount on the camera itself, which is a more serious problem (unless the mounts on both lenses are broken).
Nikon N65 35mm... | Answered on Mar 14, 2014
Follow this link: Nikon N65 Camera Body 35mm SLR. You can buy a working replacement body for $19.99. A camera repair man will charge you three to five times the replacement cost.
If it is broken the way my EM was broken, it is not repairable. There is a working N65 body on E-bay right now for the buy it now price of $19.99: Nikon N65 Camera Body 35mm SLR
Try replacing the batteries. Low batteries cannot provide enough amperage to operate the motor.
Nikon N65 35mm... | Answered on Nov 18, 2013
You may be taking picture in very high resolution or have it do extremely fine compression
Nikon N65 35mm... | Answered on Oct 23, 2013
The frame count is displayed on the panel atop the camera. See page 21 of the manual: http://butkus.org/chinon/nikon/nikon_n65/nikon_n65.htm
If you have the lens set to the lowest number, you should be seeing a FEE error on the display. The lens needs to be set to the highest number, typically 16 or 22.
Nikon N65 35mm... | Answered on Oct 19, 2013
At first glance it seems your camera may need repair. First thing I would do is clean the contacts that read the cartage. Put in a cartridge that you can afford to play with. Put the lens cap on keeping light from exposing the film, fire off the frames until it stops. If it still stops at 24-26 rewind the film (hope you have a film puller). Open the camera back fire off some shots then replace the film trying it again. If that does not work the counter is in need of repair.
However, I would not repair it I would purchase another film camera such as the Nikon N80 and if you can afford it the F100. Both are much superior to the N65. You can find N80 at KEH.com for less than $100, As of today, 2013-10-17, I see one in E+ condition for $76, a N65 for $14.
Nikon N65 35mm... | Answered on Oct 18, 2013
Nikon N65 35mm SLR Camera Logo
103 questions posted
Top Nikon Photography Experts
Ric Donato
pictureman4u
Jeff
Jeff
Are you a Nikon Photography Expert? Answer questions, earn points and help others
View Most Popular
Nikon Photography
  • Nikon Photography
Most Popular Question
picture turn
  • Photography
