SOURCE: dishwasher door latch
Check for a couple of screws to the left and right of the latch handle. Remove them and the unit should slide out and allow you access... By the way...if they are loose, tighten them first...you may just fix the problem.
SOURCE: soap door latch won't latch close
Make sure the dial that you turn to start the dishwasher is all the way to the beginning. Sometimes my little grandson comes by and plays with it, turning it. I load, add soap and the dispenser won't close. I check the outside dial, and sure enough, set it to the very beginning and the dispenser locks in place!
SOURCE: the dishwasher won't turn on
sounds like a problem with the door iterlock switch most of them have a small micro switch when you shut the door it activates the system quite easy to do but can be a bit fiddly
SOURCE: Frigidaire Dishwasher (model FDB1050REB0) Wash Light Flashing
Well, I've got a different problem. I need a control module!!!
BUT!
The flashing WASH light appears to indicate the door latch (switch) is not fully engaged. I proved that I mine which works, just doesn't pump out/drain water. If I unlatch the door and then press START, the WASH light blinks.
*WARNING* 120V ELECTRICAL CURRENT! ONLY ATTEMPT THIS IS YOU KNOW WHAT YOU ARE DOING!
The switch is located behind the control panel (5 screws from the inside.) The Hot (Black) AND Neutral (White) wires comes from the electrical input and pass through the switch. You can do a simple continuity check with the power disengaged to test the path through the switch and into the control module (pins 3 & 9m black and white).
Now... anyone have a Control Module (working) they want to give/sell to me so I don't have to go buy a new dishwasher? I just replaced the drain valve on mine :( If you do, you can send me a note vidioteic (at) gmail (dot) com
Happy Washing!
SOURCE: my bosch dishwasher door will not latch. It
Same model. Mine acts like it thinks it is closed. It doesn't latch, and the cycle still runs when you open.
Good Afternoon Marcia - Try resetting the unit by either unplugging it or flipping the household circuit breaker to the off position. Wait roughly ten minutes and turn on the dishwasher. Confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: wiring failure, damaged cord, faulty door latch assembly or control board. Because it could be a number of any one of several underlying causes, I would recommend contacting a professional to properly diagnose and repair the unit.
The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
Hi - The issue may lie with the door latch; a door switch is used to start and stop your dishwasher. It's a safety feature that won't allow water to flow with the door open. With a faulty door switch, there is a chance your dishwasher won't start at all. Dishwasher door switches are about an inch long. They are usually black but can be red. There are metal prongs on the body of the switch called terminals. Some door switches have two terminals and some have three. If your door switch is OK, check the timer assembly. This controls when and how long power is sent to other controls on your dishwasher. If these controls don't receive power, they won't work. The timer assembly contains a motor. Check this motor as well. It is often cheaper just to replace the timer motor rather than the complete assembly. My last suggestion is to check the cycle selector switches. These switches indicate cycles for washing, drying, and setting the temperature of the water. If one of your switches is the problem your dishwasher may not start. Dishwasher cycle selector switches tell the timer which cycle to run by opening and closing electrical circuits. Most selector switches are six to eight inches long. They are usually black and have terminals. By testing each one of these parts with an ohmmeter you should be able to determine why your dishwasher is not working. It is possible for other parts to fail but these are the most common parts to check. If any proves to be ineffective, I strongly suggest contacting a professional to move forward accurately.
