20 Most Recent Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Questions & Answers
3answers
Jenn Air dishwasher door won't close
i had the exact same issue. it's a broken latch mechanism, and is a fairly common problem.
i bought the part at my local repair shop for $45 (you can find it online for $30). it literally took 10 minutes.
you need to right size bit to remove the 10 bolts on the interior of the door. once you have those out, the latch slides right out of the top. there are 2 electrical connectors (careful - you can get a shock. disconnect the 2 connectors, reconnect to the new one, and zip your 10 bolts back in. super easy
3/19/2019 8:51:23 PM • Jenn-Air 24 in.... • Answered on Mar 19, 2019
Dishwasher was making a loud hum. I turned it off
The loud humming noise can be due to the pump sticking if a piece of debris gets trapped in it or an intermittent fault on the pump capacitor or starter relay. Check out these links below to get tutorials and advice on how to clean the pump or change the capacitor or relay which is cheap and simple job. How to replace Dishwasher pump Bosch Siemens etc Dishwasher Repair Manual Table of Contents http://www.ukwhitegoods.co.uk/help/fault-codes/dishwasher-fault-codes.html?start=25 I hope this helps
2/6/2018 4:03:40 PM • Jenn-Air 24 in.... • Answered on Feb 06, 2018
SMEG SA 425 x Dishwasher - washing spinners stopped!
Can you hear the wash pump operating during the cycle? Pump could be faulty or blocked, or the pcb could be at fault
1/6/2018 9:24:26 PM • Jenn-Air 24 in.... • Answered on Jan 06, 2018
I took the inside of the door off my Jenn Air dishwasher and now it won't start
You broke it!!!!!!! Check out the wiring associated with on/off cycle. There might also be a switch by the door designed to not allow unit to turn on when door is open - check it out. It might not be engaged if the inner panel of door is not properly hitting the switch.
8/22/2017 12:04:56 PM • Jenn-Air 24 in.... • Answered on Aug 22, 2017
0answers
Jenn-Air Dishwasher Handle Loose
This worked perfectly for me. Follow the link that shows you which two screws to take out. It is one screw on each side of the inside door frame. One on the left and one on the right (not the top one, but the second one down). Then pull the door handle upward about 2 inches and the whole washer face comes up. Jiggle it off and tighten the handle. Only tricky thing is that you need a star screwdriver.
The problem I had in the beginning was that I took off the middle screws on top (cause that's what it looks like in the picture), but it's actually the side screws. Don't take them all off - just the two you need.
- Pokey
11/2/2013 5:37:48 PM • Jenn-Air 24 in.... • Answered on Nov 02, 2013
Control panel won work power
yes the have power cord. see this steps and fix it.God bless you1. No power to the dishwasher Make sure there's power getting to the dishwasher. Check for a tripped circuit breaker or a blown fuse. Check the wall socket for power. Sometimes the power cord disconnects at the dishwasher (inside the junction box, behind the bottom kick panel), if this is the case, the wiring must be repaired or replaced. 2. Door switch Replace if defective. 3. Timer or Control Electronic Replace if defective (note: uncommon problem). 4. Selector switch Replace if defective (note: uncommon problem). Read more: http://www.appliancepartspros.com/repair-help/dishwasher-repair-help.html#ixzz2aaj83j00 http://www.appliancepartspros.com
7/31/2013 3:51:25 AM • Jenn-Air 24 in.... • Answered on Jul 31, 2013
Jenn-Air 24 in. JDB1100AWS Built-in Dishwasher Logo
126 questions posted
Top Jenn-Air Dishwashers Experts
Mike Cairns
Mike Cairns
Renee Knafel-Bullock
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
View Most Popular
  • Jenn-Air Dishwashers
Most Popular Question
leaks onto floor
  • Dishwashers
