The cold water stopped working... it is not frozen... the hot water works but when i put it on cold nothing comes out... i disconnected the hose and made sure the screen was not clogged(it was not clogged i blew through the hose..)
i hooked the cold water hose up to the hot water hook up and turned the washer to hot and of course the cold water came out...
i have a one handle bathtub faucet cold side works fine when you turn it to the hot side water stops coming outi have a one handle bathtub faucet cold side works fine when you turn it to the hot side water stops coming out
AnonymousMar 25, 2014
i have checked hoses and they both are producing water to machine but only hot water will work on the machine when switched to cold nothing happens and no water comes outi have checked hoses and they both are producing water to machine but only hot water will work on the machine when switched to cold nothing happens and no water comes out
AnonymousMar 26, 2014
water isn't shutting off when you hook hot water hose to itwater isn't shutting off when you hook hot water hose to it
You can't post conmments that contain an email address.
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Lift the top of your washing machine by unscrewing the back or remove the back and you will find a code and test sheet inside, you normally will find it at the top edge of the machine from or back. Very easy to use if followed to a T.
it could be frozren depends the temp. of the room u have it in. if thats the case get ur blow dryer out put heat to it. my boyfriend and i have had to do this to our pipes 3xs already.my cold water in the kitchen did to, i just turned it on and waited for it to unthaw. i hope this will help.
Check the supply hose filter, and the filter on the intake of the solenoid. Switch the wires on the solenoid to see if rinse will put hot water into the machine, the contact at the timer may be going bad. While reversed, see if it puts cold water into the wash, that will test the solenoid.
If your washing machine will not fill, only hot or cold will fill or is slow tofill then read these tips. I have covered many of the things that can happen inthese tips...
you can switch the hoses to verify that the temp selector is working if you have the cold water supplied to the hot side and run the machine on hot-cold side and nothing comes out then replace the water inlet valves.
My bet is that your cold water screen is plugged...
If your washing machine will not fill, only hot or cold will fill or is slow to fill then read these tips. I have covered many of the things that can happen in these tips…
If your washing machine was working just fine, and now it won't fill with water or spin, try this first. This is what was wrong with mine, a pressure hose had a clog in the line. First take off the front panal of washer, then connected to the load size dial (small to large load) there will be a clear plastic tube. This tube had what just looked like a stain in it, but in fact it was pluged up and was the whole problem. If the washer already thinks it's full of water, it's not gonna fill or spin..........
