After taking the motor cover off, I did not find a REED SWITCH but did find out that the incline motor was locked up. I do appreciate the solution. It got me to the point to find my real issue.After taking the motor cover off, I did not find a REED SWITCH but did find out that the incline motor was locked up. I do appreciate the solution. It got me to the point to find my real issue.
You can't post conmments that contain an email address.
1) you must adjust the REED switch, clean it and tight the wires connector very well.See the diagram 2) when you fix it, RUN the software calibration for diagnose, troubleshooting and fix it. God bless you
please keep from standing on your machine once you turn it on and test the buttons to notice if you experience anymore beeping. If not, then the area below the belt might need some oil to lower friction. If so, please check that all covers for any power source or circuitry are put into place properly. Otherwise, you might need to have the
While the PS3 system is in standby mode (red light on the front of the system), hold down the touch-sensitive On/Off button on the front of the system until the PS3 beeps a second time (approximately 5 seconds), then release it.
The PS3 will power up, the Video Output Settings will automatically reset to the standard resolution (or detect the current display output settings of your TV/monitor).
You can download the manual in PDF Adobie Acrobat form here http://www.iconservice.com/CustomerService/manualsProductManuals.do?model=24811&modelName=NORDICTRACK+ELITE+ZI+TREADMILL&version=0&company=11&language=
It is probably due to the fact that your PS3 needs resetting back to standard definition. Try holding the power button down for 5 seconds until it beeps. It should then revert back to standard.
Has the safety key been inserted? It sound like that what is missing for it to work if that the case call Iconfitness @ 1-800-999-3756.
Part #: 264413 Part Name: ASSY,CLIP,ROPE/KEY Model: 248110 - NORDICTRACK ELITE ZI TREADMILL Part List: #264413 - KEY/CLIP Quantity on Model: 1 Price: $9.82
