Tried cleaning, tightening bobbin, changing tension settings and still nothing
Hi:
Ok... so try to remember that loopy stuff on top means the bobbin tension is too loose (or the top tension is too tight...)
Loopy stuff on bottom, means the top tension is too loose. (or it's not threaded right)
Now. Get some scrap of the same material. Loosen that bobbin back to where it was. RETHREAD the top, with the foot in the UP position.
Place your scrap under the foot, and sew. still have problem? clip your threads and try again only this time hold the top and bottom threads off to the side as you begin to sew. How did that do?
Adjust the top tension to the point where you start seeing the bobbin thread come up in loops to the top... then back off until the disappear.
Now... be sure you have the correct thread and needle for your fabric. A lot of problem are caused by not having the proper needle and thread.
Testimonial: "thank you very much i did all these steps i'm not sure which helped but it did, thank you, thank you, many thanks"
You are most welcome. I am very happy that you were able to get it sorted out and that my instruction helped in some way. Tension issues are some the most frustrating parts of sewing for the novice. In the future remember to make your tension changes in very small increments. (a smidge at a time) Happy Stitching!
SOURCE: I am using my new
Hi. You "feel" that the machine is threaded correctly? You should probably completely pull the thread out and start over, making certain that it is threaded correctly. Once that is done, double check to make sure the thread is pulled all the way into the tension discs. Make sure also that you have lowered the presser foot. Is the bobbin inserted in it's case correctly? Every aspect is critical to proper function. You may also want to revue your manual.
