Acer Aspire 5742 Notebook Logo
Posted on Jul 04, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Acer aspire 5742 does't keep power on battery. itis shutdown imediatly.. how can to fix?
Anonymous
Level 3:
  • Acer Master 6,771 Answers
  • Posted on Jul 04, 2012
Anonymous
Acer Master
Level 3:
Answers
6771
Questions
0
Helped
1779413
Points
21413
If the power adapter runs the laptop, it is likely the rechargeable battery needs to be replaced. Go to www.ebay.com Type: make and model of laptop, refine search for battery.
5 Related Answers
RICHARDM69
Desktopsbyduck-Computers
  • 1061 Answers
  • Posted on Dec 05, 2008
SOURCE: windows xp on acer aspire 4315 cannot shutdown normally
ARE YOU SAYING YOU SHUT DOWN WITH THE POWER BUTTON.GO TO START RUN AND SHUTDOWN OR RESTART THERE.RICHARDM69
Anonymous
  • Posted on Feb 09, 2009
SOURCE: Battery not charging when Laptop powered on Acer Aspire 4520
replace the battery of lappy
Anonymous
  • 381 Answers
  • Posted on May 13, 2009
SOURCE: acer aspire 4315 webcam not working
hi..ok if you installer you need to update and install the chip set drivers..thanks and good Luck...^_^
Anonymous
  • 3513 Answers
  • Posted on Mar 01, 2010
SOURCE: my acer aspire 4315 hangs during shutdown. windows XP OS
This happens when there is a process still trying to work in the back end.
Try to disable most of the applications which get opened by default when windows starts.
Click on start/run/ and type msconfig. Once the window comes up click on start up tab and disable all.
Now try to reboot the system.
Also hope there is no usb device connected at the time of shut down. This would also make xp hang.
Thanks
Anonymous
  • Posted on May 21, 2010
SOURCE: acer aspire 2920z is automatically shutdown
my acer 2920z mode laptop. is always shuting down in a regular basis.. i check the power plan settings and its says there that it will be put on sleep every 5 hours when it is plugged in.. but its shutting down every 1 or 2 hours of use.. kindly please give a assistance.. thanks and have a nice day
Power light keeps flashing when in sleep mode
It is normal -this indicates that the laptop is in "sleep" mode & NOT in shutdown mode.
I have a acer 5741. I have tried many times to charge it but it wont charge no matter how long i leave it plugged in. It is stuck on 10%. When I plug it in it says its charging but nothing actually...
1. Unplug AC adapter. Shutdown
2. Remove battery, Connect AC Adapter
3. Start windows7. Remove Microsoft ACPI-Compliant Control Method Battery under device manager , battery
4. Shutdown, Remove AC Adapter, Install battery, Reattach AC Adapter.
5. Power up -
Now Plugged in and Charging.
My acer aspire one keep shutting how and how it not even boothing up
1- Scanning computer to eliminate malwares, spywares and the viruses from your laptop.
2- Repairing and cleaning Windows registry.
These two tips are found to be very helpful to fix the laptop shutdown problem. Almost all the computer users surf internet which could result in viruses attacking your system. Some of these infections are really pesky and cause the machines to shutdown randomly.
The registry errors, however, are the internal errors and can become a cause of system crashes and freezes. The registry keys shall be in good health to keep a system perfect.
When I noticed my laptop keeps shutting down everytime, I tested the Intel Software Partner, RegInOut to fix the random shutdown problem with my laptop.
1helpful
Have a acer aspire 5520,it has developed several problems,1, will often freeze on full screen mode,have to shut it down and restart,2, will keep on shutting down after battery light starts flashing,will...
1. Check your power cord & adapter.
2. If its working then check the battery, reseat the battery & check.
3. If available then check with another battery
4. If no, then remove the battery & switch on the PC in AC mode.
5. Check if battery charging indication or AC power on indication is glowing. if not then need to change ur motherboard.
6. If indication is OK, but could not power ON then check ur RAM for any loose connection or dust. clean & reinstall.
7. If still no display, connect an external monitor, check if display is comming.
8. If Display is coming then your LCD need to replace.
2answers
Acer aspire 2920z is automatically shutdown only message appear warning critical battery low and then shutdown
Sounds like your battery is faulty and not charging. Try replacing the battery or just use the mains lead with the battery removed. If this keeps happening replace the system board
2answers
Acer aspire 4520g cannot start
I am assuming it does this even if it is plugged into power supply. Try removing the battery and then re-installing it. Maybe it has come loose or has a bad connection. When the power supply is hooked up does it show that the laptop is charging? Have you left the charger on there overnight? Maybe the battery is really weak. It sounds like a bad battery to me but the only way to know for sure is to buy a new battery or test it with another good battery and see if it does the same thing.
2answers
When i put my aspire one laptop on,it shows the green light without coming up and i have changed the battery as well as the power pack and itis still the same
Its might be due to the RAM ...please try to replace the RAM ... If then not worked its your motherboard needs to be replaced ..
thank u
1helpful
3answers
Windows xp on acer aspire 4315 cannot shutdown normally
1helpful
6answers
Acer 1640
  • shutdown and power off your acer laptop
  • then remove the battery out of laptop
  • connect the power and switch on ur laptop
  • let it boot to operating system
  • check if its working now? ur keyboard and mouse should be working now
  • you can now connect the battery and keep working.
  • if u want to power off, put ur laptop in hibernate more, rather than shut-down. so u dont have to reboot next time without battery.
  • if u restart or start ur laptop after a shutdown, make sure to remove the battery first
    i hope this will help.
more details can be found on the cnet forum @ http://forums.cnet.com/5208-6620_102-0.html?forumID=44&threadID=294657
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
