20 Most Recent
Acer Aspire 1642WLMi Notebook Questions & Answers
Where can I download the drive for my hard drive?
Hard drives are a drive if you are referring to drivers Click start control panel administration tools computer management device manager scroll through all of your devices If you see a yellow question or exclamation mark ? ! or a red X you will need to update the drivers for this device right click select update driver/reinstall driver if you can see your usb device but its not working scroll to Ports(Com&Ltd) right click to update driver If you computer came with a motherboard disk the drivers could be on it.
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8 it might take some time being a freeware driver solution Note: it will find all of your outdated drivers This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point. Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Acer aspire 1642WLMi shuts off
The suggestion "B" seems to be the most valid. You would need to open up the laptop and visually inspect the power connector solder joint. "cold solder" is one of the most common issue with electronic circuit.How old is the laptop?
Location of wireless switch
Hi.The wireless switch is on the front left of the laptop near the mic and headphone sockets and usually has an amber LED light.Regards.
Acer 1640
- shutdown and power off your acer laptop
- then remove the battery out of laptop
- connect the power and switch on ur laptop
- let it boot to operating system
- check if its working now? ur keyboard and mouse should be working now
- you can now connect the battery and keep working.
- if u want to power off, put ur laptop in hibernate more, rather than shut-down. so u dont have to reboot next time without battery.
- if u restart or start ur laptop after a shutdown, make sure to remove the battery first
i hope this will help.
more details can be found on the cnet forum @
http://forums.cnet.com/5208-6620_102-0.html?forumID=44&threadID=294657
How do i switch on the wireless conection
hey
It's on the very front of the laptop next to the headphone, microphone ports. Its usually a slide switch indicated by and LED light.When its on ,on ur right side it will display the the wireless netwrok is on
Lost Bios password for acer aspire 1640
The password exists for your protection -- to prevent a thief from taking and using your computer.
Find your original sales-receipt, to prove that you are the owner, and contact ACER, and they will be able to assist you.
Where can i find the
If there is a switch it will be a slider on the front (accessible when the lid is closed) near the wireless light. Maybe 1/3 of the way along from left?
Wlan doesn't work after installation
You will have to find out what Wlan card you have and install the updated driver this can be frustrating go to acer.com then go to support then go to download and get the updated driver the hard part is finding what card you have you may have to try several drivers before you get the right one.
Chris Thrash
B52Computers
I want to know if
Hi
Most newish laptop HDD now can be upgraded up to about 500GB should be fine if you google harddrives or look on ebay you should find one that you want weather it is sata or ide
just make sure that you check what sort you have before you buy
happy hunting
Yellow stripe down the screen.?
And a good evening to you!
It is possible that you have a bad LCD assembly, or possibly the LCD cable connector is loose. The only way to find out is to remove the LCD assembly from the top cover so that you can access the connector. It is located behind the LCD screen.
If you want a copy of a service manual for the disassembly process, let me know and I'll see what I can do for you.
Ron-
