My 2003 Whirlpool Senson Dryer is making a loud roaring sound when it is operating. It still dries the clothes and otherwise operates normally. It just makes this roaring noise while it's on. Is this a maintenance problem? Could this lead to more problems?
Does the roaring sound occur after the machine warms up? If so, it could be a bad drum bearing. the heat from the dryer causes it to expand in its housing and, since it may been defective, could start "roaring". If so, The dryer drum shaft/bearing assembly will need to be replaced
If however, the roaring is immediate upon start up then u may have a bearing in your dryer motor. The entire motor may have to be replaced.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you for taking the time to educate me. " - teresa241964
