NorStar Startalk Flash 2 Phone Logo
Posted on Dec 03, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Can I please get help with finding the Norstar Flash Voicemail Manual, installation guide
george peters
Level 3:
President:
  • NorStar Master 860 Answers
  • Posted on Feb 18, 2009
george  peters
NorStar Master
Level 3:
President:
Answers
860
Questions
0
Helped
609338
Points
3471
  • steve buck Dec 08, 2010
    Good help is hard to find so I sure appreciate the post for the Startalk
Not the normal voicemail problems
Before you can do anything you need a M7310. Programming a Nortel voice mail requires M7310. It uses the 3 soft keys under the display to program it. You can get one cheap on EBAY. Next you need to find out what type of Voice Mail System in connected to your Nortel phone system. Below is a link to a Older StarTalk manual. You may have a StarTalk, StarTalk Flash, or a Call Pilot.
http://www.myuserguides.com/Nortel_Norstar_Startalk.pdf#page=15&zoom=auto,-69,407
Below is a link that tells how to reset the System Manager Password.
Reset Admin Password Norstar Meridian and Nortel BCM Help Guides
The default code and password for System Admin is F983 and 1020000 or 1021111. The photo below shows a system admin programming tree. Hope this helps
Charlie
Why would a NorStar StarTalk suddenly stop accepting voicemail calls?
"Q: My Norstar Startalk, Flashtalk, or voice mail says my mailbox is not accepting any more messages. I deleted all my messages, but callers still cannot leave a message. Why?
A: Check with your voice mail administrator. Chances are another Mailbox on the system used up all the message storage space. Usually it's the general delivery mailbox that hasn't been checked for messages on a regular basis."
Frequently Asked Questions
The following discussion suggests that voicemail can be inactivated, and cab be re-activated by logging in and pressing '4'
Startalk Flash Won answer Nortel Phone System Tech Support
This says that the mailbox must be initialized.
http://www.uniquecomm.com/docs/Startalk_Flash_Quick_Reference_Guide.pdf
Norstar m7130
Not to be too obvious, but did you mean Feature*98?
Even then, it should be F*981, or another in that group:
Voicemail Feature Codes Norstar Meridian and Nortel BCM Help Guides
Norstar flash errasing message
Reboot the voice mail system.
If still an issue call in a tech/vendor.
1helpful
When I check voicemail it says Flash busy and I can't enter the password..
They would be logged into the voicemail either using the open voicemail key or feature 981. It's a good guess that they aren't.
How long has the voicemail been tied up?
2answers
Norstar system won't recognize any features We had a power outage and now our phone system will not recongnize the voicemail or mailbox features. Is there any way to fix this? Thanks
Depending on the type of voicemail it can take up to 10 min, to fully come up. Is the power light lit in the voicemail cabinet? Also what kind of voicemail is it?
2helpful
Trying to reset the admin password on a Norstar Flash
Does reset pswd come up on the right hand side of the display if so there is a key just below that that you press called the soft key
3helpful
3answers
My phone on our Norstar system rings & rings & never goes to voicemail. Other sets on this system ring 4 times & then automatically go to voicemail. How do I cjange my set?
Fress F985 u will get voicemail DN. Note down ur voice mail DN.
Go to programming of Norstar which will be F**266344 password will be 266344.
Dispaly shows u terminal and extensions.
press show
then next display will show u capabilities.
Press show then next display will show u FWD no answer.Press show then change put the voicemail Dn which u had written then next.
Now call will go to ur voicemail provided u have ur own presonal mailbox. If it is not there u will have to createe it otherwise it will go to general delivery mailbox.
Hope it will be helpful for u.
Thanks.
Norstar Flash problem
Cycle the power on the voicemail system. If that does not work, you may have to replace the voicemail power supply, or send the voicemail system for repair.
Good Luck!
Top NorStar Lands Phones Experts
Paul Bade
Daniel Blask
Daniel Blask
Are you a NorStar Lands Phone Expert? Answer questions, earn points and help others
