Roper REX4634KQ Electric Dryer Logo
Posted on Dec 01, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Roper dryer I have a Roper dryer that only runs when you hold the start button! everything works when depressed but shuts down when released! Any Ideas?
Dan Webster
Level 3:
  • Roper Master 8,221 Answers
  • Posted on Dec 16, 2008
Dan Webster
Roper Master
Level 3:
Answers
8221
Questions
5
Helped
2381211
Points
25840
Replace the motor, the run winding is shot.It is not hard to replace the motor. The blower has reverse threads(righty loosy). The motor has a quick connect(no wiring needed). Yank out the filter first.Remove the 2 screws in the filter housing on top.Then use a putty knife to pop the top. Remove the screws holding the front panel on. VERY IMPORTANT! Raise the front up an inch before pulling forward or the panel clips will break! Some models have a panel on bottom. If they do then this panel must come off first. Then you remove the door springs and back off the screws holding down the bottom of the door panel. Then pop the top and remove the screws on top to get the panel out of your way.Get the idler loose and remove the drum. Clean it all up and replace the motor. I can do it in 20 minutes. It is simple and uncomplicated. Go for it.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Roper dryer repair manual
90% it's the timer
Jan 30, 2014 • Dryers
My Roper dryer heats up but does not turn when I push the start button. What would cause the dryer to not spin?
one is the belt may be broken or have slipped off the pulley.the door switch could also be bad. try and hold the door open and depress the door switch at the same time someone is pushing/turning the start button and then try to rotate the drum be hand and see if it will turn. the motor could have alot of lint build up and cause the motor not to turn.
Press start button and dryshuts off when start button is released
There is a switch assembly on the motor that activates when the motor is running. Centrifugal switch. It keeps it running when you release the switch. That is where to start. Eric
6helpful
3answers
Asko Dryer stops running when you release the start button.
Hi, this is a simple issue here. these switches will fail from time to time. the start switch is unable to hold the circuit, in return, opening it upon release of the button.
Simply replacing the switch will fix this issue. switch is 20 dollars tops.
I am trying to fix a rooper elecetric dryers that starts on the push button but shuts down when evere the start button is released. The dryer would normally stay in the run mode once the start button is...
IF YOU HAVE A METER YOU CAN CHECK THE START BUTTON ON OHMS,CLOSED AND GET A READING GOOD,OPEN AND GET NO READING GOOD,OR JUST A WIRE ACROSS THE SWITCH TO SEE IF THE MOTOR STARTS RUNNING,IF ALL THAT FAILS I WOULD SAY THE MOTOR IS BAD,LET ME KNOW-MIKE
Dryer starts when start button is pressed and held but will not stay running when button is released
there is a holding contact at the motor wiring, check the schematics and trace that holding contact. it should hold the motor running as soon as it starts.
tnx 4 using fixya,
drcool
Roper RGX4634KQ will run for 3 minutes then stop.
if you can restart after it stops but have to wait 30 mins or longer suspect bad motor
3answers
Roper REX4634KQ
That should be just a push to start switch. The start switch is inside the motor. When the motor turns fast enough it trips an internal switch to keep the motor running. It sounds like you have a motor on the way out.
Top Roper Dryers Experts
ZJ Limited
ZJ Limited
Mike Cairns
Mike Cairns
CJ Rock
CJ Rock
Are you a Roper Dryer Expert? Answer questions, earn points and help others
